Hi all,
I was about to publish a map to the ArcServer but (not sure since when) every layers that I have in the map shows
Code 24011 Layer's data source is not registered with the server and data will be copied to the server
all layers are in SDE server and all connected fine.
also when I check server properties
Server Properties > Data Store > Registered Databases
there are registered databases that I use.
Now what should I check to solve this problem?
I've watched videos that registering databases and folders.
Thank you,
Jack
