detroit
"Routing" implementation
Discussion created by detroit on Nov 14, 2013
Is there any ESRI implementation regarding routing. I have a pipe with valves. They pipes and valves are not linked by any means other then by geometry (there's no data linking them). I figured the fastest way to jump through nodes is by using buffer over valve and getting the pipes and jumping to next and so on and so forth. How did you guys solve any sort of routing problems? Any hint is welcome.
Regards,
Matej
Outcomes
