azatrain
Navigation Control Style does not Allow Rotation
Discussion created by azatrain on Nov 13, 2013
Latest reply on May 27, 2014 by xtian79
I am using VS2010, Expression Blend 4, and Runtime 10.1.1.  I want to tap into the control template for the Navigation control so that I can play with what happens when the full extent button is clicked.  I used Expression Blend to get at the control template and I've got the full extent stuff working great.  What is weird is that the navigation control will no longer allow me to rotate the map.  I get this error in the XAML code at design time.
'System.Windows.Media.Animation.DoubleAnimation' animation object cannot be used to animate property 'RenderTransform' because it is of incompatible type 'System.Windows.Media.Transform'.
The offending code from within the control template is shown below.  I'm not sure how the control can work fine if I don't specify its own style, but when I specify this style it won't rotate.  Has anyone else run into this?  If so, how did you work around it?
<VisualStateManager.VisualStateGroups>
                                <VisualStateGroup x:Name="CommonStates">
                                    <VisualState x:Name="Normal">
                                        <Storyboard>
                                            <DoubleAnimation Duration="0:0:0.1" To="0.75" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleX)" Storyboard.TargetName="LayoutRoot"/>
                                            <DoubleAnimation Duration="0:0:0.1" To="0.75" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleY)" Storyboard.TargetName="LayoutRoot"/>
                                            <DoubleAnimation BeginTime="0" Duration="0:0:0.1" To="0.25" Storyboard.TargetProperty="(UIElement.Opacity)" Storyboard.TargetName="LayoutRoot"/>
                                        </Storyboard>
                                    </VisualState>
                                    <VisualState x:Name="MouseOver">
                                        <Storyboard>
                                            <DoubleAnimation BeginTime="0" Duration="0:0:0.1" To="1" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleX)" Storyboard.TargetName="LayoutRoot"/>
                                            <DoubleAnimation BeginTime="0" Duration="0:0:0.1" To="1" Storyboard.TargetProperty="(UIElement.RenderTransform).(ScaleTransform.ScaleY)" Storyboard.TargetName="LayoutRoot"/>
                                            <DoubleAnimation BeginTime="0" Duration="0:0:0.1" To="0.75" Storyboard.TargetProperty="(UIElement.Opacity)" Storyboard.TargetName="LayoutRoot"/>
                                        </Storyboard>
                                    </VisualState>
                                </VisualStateGroup>
                            </VisualStateManager.VisualStateGroups>
Outcomes
