Solved! Go to Solution.
deferred = new dojo.Deferred(); deferred.then(function(value){ console.log(value); map.addLayers([needPoints, needRoutes, needAreas]); });
deferred.resolve("success"); return deferred.promise;
myQuery.on('complete', initEditor);
queryTaskDocs = new esri.tasks.QueryTask("server_path"); var queryDocs = new esri.tasks.Query(); queryDocs.outFields = ["DOC_TITLE2"]; queryDocs.returnGeometry = false; queryDocs.where = "DOC_TITLE2 <> ''" queryTaskDocs.execute(queryDocs,function(results){ //Populate the dropdown list box with unique values from DOC_TITLE2 field var docs; var values = []; var testVals={}; var features = results.features; dojo.forEach (features, function(feature) { docs = feature.attributes.DOC_TITLE2; if (!testVals[docs]) { testVals[docs] = true; values.push({name:docs}); } }); store1 = new dojo.store.Memory({data:values}); dijit.byId("docSelect").set("store", store1); }); dojo.connect(queryTaskDocs, "onComplete", map.addLayers([featurePoints, featureRoutes, featureAreas]));
queryTaskDocs.execute(queryDocs,function(results){ //... dijit.byId("docSelect").set("store", store1); map.addLayers([featurePoints, featureRoutes, featureAreas])); }); //no need for this anymore //dojo.connect(queryTaskDocs, "onComplete", map.addLayers([featurePoints, featureRoutes, featureAreas]));
<!DOCTYPE html> <html> <head> <meta http-equiv="Content-Type" content="text/html; charset=utf-8"> <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10"> <!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices--> <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"> <title>Add New Needs</title> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dijit/themes/claro/claro.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/esri/css/esri.css" /> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dojox/grid/resources/Grid.css"> <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/js/dojo/dojox/grid/resources/claroGrid.css"> <style> html,body{height:100%;width:100%;margin:0;overflow:hidden;} #map{ padding:0; } .dj_ie .infowindow .window .top .right .user .content { position: relative; } .dj_ie .simpleInfoWindow .content {position: relative;} </style> <script>var dojoConfig = { parseOnLoad:true };</script> <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.5/"></script> <script> dojo.require("dijit.dijit"); // optimize: load dijit layer dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("esri.dijit.Geocoder"); dojo.require("dijit.layout.StackContainer"); dojo.require("dijit.MenuBar"); dojo.require("dijit.PopupMenuBarItem"); dojo.require("dijit.DropDownMenu"); dojo.require("dijit.MenuItem"); dojo.require("esri.layers.FeatureLayer"); dojo.require("dojo.parser"); dojo.require("dijit.form.ComboBox"); dojo.require("esri.dijit.editing.Editor-all"); dojo.require("esri.SnappingManager"); dojo.require("esri.dijit.editing.AttachmentEditor"); dojo.require("dijit.form.Select"); dojo.require("dijit.form.ComboBox"); dojo.require("dojo.store.Memory"); dojo.require("dojo.Deferred"); var map; function init() { console.log("drop line 1"); esriConfig.defaults.io.proxyUrl = "/proxy"; //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications. esri.config.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer"); var customExtentAndSR = new esri.geometry.Extent({"xmin": -134.060026464775,"ymin": 32.885241223675,"xmax": -110.305411069225,"ymax": 42.2934163323251,"spatialReference": {"wkid": 4326}}); map = new esri.Map("map", {extent:customExtentAndSR, zoom: 11}); dojo.connect(map, "onLayersAddResult", initEditor); var basemap = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Street_Map/MapServer"); var needPoints = new esri.layers.FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/FeatureServer/0"); map.addLayers([basemap, needPoints]); var queryTaskDocs = new esri.tasks.QueryTask("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/SanFrancisco/311Incidents/MapServer/0"); var queryDocs = new esri.tasks.Query(); queryDocs.outFields = ["req_type"]; queryDocs.returnGeometry = false; queryDocs.where = "req_type <> ''" queryTaskDocs.execute(queryDocs,populateListDocs); console.log("drop line 3"); } function populateListDocs(results) { console.log("drop line 4"); //Populate the dropdown list box with unique values var type; var values = []; var testVals={}; var features = results.features; dojo.forEach (features, function(feature) { type = feature.attributes.req_type; if (!testVals[type]) { testVals[type] = true; values.push({name:type}); } }); store1 = new dojo.store.Memory({data:values}); dijit.byId("docSelect").set("store", store1); def.resolve(); console.log("store is set"); }; function initEditor(results) { alert("this is just here for now"); console.log("drop line 5"); var templateLayers = dojo.map(results,function(result){ return result.layer; }); console.log("drop line 6"); var templatePicker = new esri.dijit.editing.TemplatePicker({ featureLayers: templateLayers, grouping: false, rows: 'auto', columns: 3 },'templateDiv'); templatePicker.startup(); //widget used for the attribute inspector custom field var docSelect = new dijit.form.ComboBox({ id: "docSelect", name: "docSelect", store: store1, }, "docSelect"); var layers = arrayUtils.map(evt.layers, function(result) { return { featureLayer: result.layer, showDeleteButton:true, fieldInfos:[ {fieldName: "req_id", visible: true, 'label':"id", 'customField': docSelect}, {fieldName: "req_type", visible: true, 'label':"req type", 'customField': docSelect} ] }; }); var settings = { map: map, templatePicker: templatePicker, layerInfos:layers, toolbarVisible: true, createOptions: { polylineDrawTools:[ esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYLINE], polygonDrawTools: [ esri.dijit.editing.Editor.CREATE_TOOL_FREEHAND_POLYGON, esri.dijit.editing.Editor.CREATE_TOOL_CIRCLE, esri.dijit.editing.Editor.CREATE_TOOL_TRIANGLE, esri.dijit.editing.Editor.CREATE_TOOL_RECTANGLE ] }, toolbarOptions: { reshapeVisible: true } }; console.log("drop line 8"); var params = {settings: settings}; //Create the editor widget var myEditor = new esri.dijit.editing.Editor(params,'editorDiv'); //define snapping options var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_CROSS, 15, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0, 0.5]), 5), null); map.enableSnapping({ snapPointSymbol:symbol, tolerance:20, snapKey:dojo.keys.ALT }); myEditor.startup(); } console.log("drop line 9"); dojo.ready(init); </script> </head> <body class="claro"> <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;"> <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'"> Edit Hydrography </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;"> <div id="templateDiv"></div> <div id="editorDiv"></div> </div> <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div> </div> </body> </html>
dojo.connect(map, "onLayersAddResult", function(results){myResults = results;});
