Synchronize Geodatabases
1964
11-10-2013 01:35 AM
User35489
Occasional Contributor III
Good Day Guru's,
We have 2 geodatbases
1. ArcSDE 9.3, Oracle 11g, ArcCatalog
2. ArcSDE 10.0, Oracle 11g, ArcCatalog-ArcINFO
Now, i have a dataset in 1st geodatabase, and the same dataset under same schema exist in 2nd geodatabase. 1st Geodatabase gets updated frequently. I want to synchronize these updates in 2nd geodatabase.
Could you please let me know
Whether these datasets must to be versioned ?
Whether synchronization could be done from 9.3 to 10.0/10.1 ArcSDE?
Your earliest response is highly appreciated
-AS
JakeSkinner
Esri Esteemed Contributor
Hi Abdullah,
Yes, the feature classes must be registered as versioned and have Global IDs:
http://resources.arcgis.com/en/help/main/10.2/index.html#/Preparing_data_for_replication/003n000000z...
Also, you will be able to replicate data from a 9.3 to a 10.x geodatabase:
http://resources.arcgis.com/en/help/main/10.2/index.html#//003n000000z3000000
JakeSkinner
Hi Abdullah,
