I'm trying to get the popup/mobile popup working. https://developers.arcgis.com/en/javascript/jssamples/widget_mobilepopup.htmlFor my code the pop works, but I need it to be more like the sample and allow me to select more than one feature at a time, when this happens the popup states (ex. 1 of 3) and allows the users to scroll throw the selections. What am I missing. I can get the sample to work but I can't use a web map I need to use my own service. Can someone show me a sample with popup mobile using just a restend point instead of a web map. Or can you tell me what I'm missing. Do I need query the featurelayer somehow; lost and confused!Thanks D-
<!DOCTYPE HTML>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=Edge,chrome=1">
<title>Map</title>
<link rel="shortcut icon" href="https://community.esri.com/favicon.gif" />
<link rel="stylesheet" href="https://serverapi.arcgisonline.com/jsapi/arcgis/3.7/js/dojo/dijit/themes/claro/claro.css">
<link rel="stylesheet" type="text/css" href="https://js.arcgis.com/3.7/js/esri/css/esri.css">
<style>
html, body, #map {
padding:0;
margin:0;
height:100%;
width:100%
popup = new esri.dijit.PopupMobile(null, dojo.create("div"));
</style>
<script src="https://js.arcgis.com/3.7/"></script>
<script>
var map;
var popup;
var tasks;
var initExtent;
require([
"esri/map",
"esri/layers/FeatureLayer",
"esri/tasks/query",
"esri/tasks/QueryTask",
"esri/tasks/GeometryService",
"esri/graphic",
"esri/dijit/PopupMobile",
"esri/dijit/PopupTemplate",
"esri/request",
"esri/geometry/Point",
"esri/graphic",
"esri/tasks/IdentifyParameters",
"esri/symbols/SimpleFillSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/renderers/SimpleRenderer",
"esri/graphic", "esri/lang",
"dojo/_base/Color", "dojo/number", "dojo/dom-style",
"dojo/dom-construct", "dojo/on", "dojo/_base/array", "dojo/domReady!"
function(
Map, FeatureLayer, Query, QueryTask,
GeometryService, Graphic, PopMobile,
PopupTemplate,
esriRequest,
Point,
Graphic,
IdentifyParameters, SimpleFillSymbol, SimpleLineSymbol,
SimpleRenderer, Graphic, esriLang,
Color, number, domStyle, domConstruct, on, array, dom
// use a proxy page if a URL generated by this page is greater than 2000 characters
// if proxyUrl is null or undefined the featureLayer.selectFeatures call will not work
esri.config.defaults.io.proxyUrl = "https://myserver/proxypage_net/proxy.ashx";
map = new Map("map", {
center: [-117.075,33.134],
zoom: 13,
basemap: "streets",
infoWindow: popup
//hide the popup if its outside the map's extent
map.on("mouse-drag", function(evt) {
if (map.infoWindow.isShowing) {
var loc = map.infoWindow.getSelectedFeature().geometry;
if (!map.extent.contains(loc)) {
map.infoWindow.hide();
var layer = new esri.layers.ArcGISDynamicMapServiceLayer("https://myserver/pubgis/rest/services/my/MapServer");
map.addLayer(layer);
var resizeTimer;
//Set info Template
var infoTemplate = new esri.InfoTemplate();
infoTemplate.setTitle("CIO ${DISTRICT}");
infoTemplate.setContent( "<b>DISTRICT: </b>${DISTRICT}<br/>"
+ "<b>POPULATION: </b>${POPULATION}<br/><br/>");
//Add Featuerlayer
var PolyFeatures = new esri.layers.FeatureLayer("https://myserver/rest/services/my/FeatureServer/1",{
mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
infoTemplate:infoTemplate,
outFields:["DISTRICT", "POPULATION"]
PolyFeatures.on("click", function(evt) {
map.infoWindow.setFeatures([evt.graphic]);
map.infoWindow.show(evt.mapPoint);
map.addLayers([PolyFeatures]);
dojo.ready(init);
</script>
</head>
<body class="claro">
<div id="map" class="map">
</div>
</body>
</html>
