AnsweredAssumed Answered
Do 10.1 tiled services work with Google Maps extension?
Question asked by mbakerDPS on Nov 5, 2013
Latest reply on Nov 6, 2013 by mbakerDPS
All,
I've got a local version of the 'tiled map' sample found at:
Homepage > Samples > Add ArcGIS Server cached map.
I swapped in a service from ArcGIS online, and swapped the API key, and the sample works fine.
Problem is when I swap in a layer from our internal server, I get an error:
400 bad request: failed to load the given URL (through Firebug)
The URL for the tiles / service that is getting called is:
http://arcgisdev01:6080/arcgis/rest/services/Maps/SchoolBoundaries_test/MapServer/tile/12/1553/853.png
...which when typed into a browser, doesn't work either.
I understand this is a legacy service - that is, we're using the old version of the Google Maps API.
EDIT: When I swap out a query layer for the same 10.1 tiled map service, the query works just fine...
The new service is version 10.1... is there a problem using 10.1 services with this API extension?
Thanks!
-m
Outcomes
