Change Z coordinates of vertexes by UpdateCursor
1420
11-04-2013 08:39 PM
YvoWeidmann
Dear list
I try to set the Z values of all vertex of individual lines by a fixed value / attribute. All vertex of a single geometry are getting the same value. Somehow I tried to set the values through the geometry object I retrieve from the cursor. But the values are not written back to the geodatabase.
updateRows = arcpy.UpdateCursor(targetLayer)     for updateRow in updateRows:         shapeObj = updateRow.getValue(shapeFieldName)         # Multipart geometries.         for partObj in shapeObj:             for pointObj in partObj:                 # Only valid points.                 if (pointObj != None):                     # Setting the values of the z cooridnates to a fixed value.                     pointObj.Z = 9999       updateRow.setValue(shapeFieldName, shapeObj)     updateRows.updateRow(updateRow)
I don't understand why the changed geometries are not written to the database. What would be the correct way to do it?
I am looking forward to any hint and ideas.
Best regards,
Yvo
XanderBakker
Esri Esteemed Contributor
Hi Yvo,
Try this:
import arcpy targetLayer = r'C:\Project\_Forums\multipart\test.gdb\myPolylineZ_multipart' shapeFieldName = 'SHAPE'  cursor = arcpy.UpdateCursor(targetLayer) for row in cursor:     geom = row.getValue(shapeFieldName)     geomArr = arcpy.Array()     for part in geom:         partArr = arcpy.Array()         for pnt in part:             if pnt != None:                 pntOut = arcpy.Point(pnt.X, pnt.Y, 9999)                 partArr.add(pntOut)          geomArr.add(partArr)      polyline = arcpy.Polyline(geomArr)     row.setValue(shapeFieldName, polyline)     cursor.updateRow(row)  del row del cursor
Kind regards,
Xander
XanderBakker
Dear list
                    pointObj.Z = 9999
Best regards,
Yvo
Hi Yvo,
The 3D Analyst extension comes with a tool to convert features to 3D by attribute: "Feature To 3D By Attribute (3D Analyst)".
If the featureclass you are updating isn't "Z-aware" you will not be able to write the Z-values to a feature. The alternative is to create a new featureclass through "Create Feature Class (Data Management)" and set the has_z to "ENABLED" and write your feature to the new feature class. Use a search cursor on your input features and an insert cursor on your output features.
Kind regards,
Xander
XanderBakker
Hi Yvo,
Try this:
Kind regards,
Xander
XanderBakker
Hi Yvo,
If you think the answer was helpful you  can use the "arrow" button in order to help other  members find useful information:
More info here: http://resources.arcgis.com/en/help/forums-mvp/
Kind regards,
Xander
