Printing with SVG PictureFillSymbol
913
10-28-2013 12:38 PM
YamunadeviRathinasamy
I am having a graphicslayer with SVG picture marker symbol, If I try print it fails.
any idea?
var PictureMarkerJSON = {};
          PictureMarkerJSON["url"] = "../../../images/myimage.svg";
//also I tried web path "http://webserver/images/myimage.svg"
          PictureMarkerJSON["contentType"] = "image/svg+xml";
          PictureMarkerJSON["angle"] = 0;
          symb = new PictureMarkerSymbol(PictureMarkerJSON);
          symb.width = w;
                    symb.height =h;
I tried print again actually it prints with default point symbol not my SVG image. any ideas would be appreciated.
ManishkumarPatel
Occasional Contributor II
Hi Yamunadevi,
Have you tried adding the MIME type in IIS to serve the .svg files. Simply add the following MIME type declarations via IIS Manager (HTTP Headers tab of website properties):
Filename extension               MIME type
     .svg                              image/svg+xml
Let me know if this works for you.
Best Regards,
Manish
Thanks Manish.
I have mime type added for .svg in my application IIS server and WebAdaptor IIS.
This svg file wrks fine on my application I can see that picture symbol on Map. Only issue is not printing. it prints just point.
I am using ArcGIS 10.1 advanced printing.
Regards,
Yamuna.
