HI,I am having some trouble making the navigation toolbar work in an application that I am porting to AMD. Everything loads fine but when I try to use the Zoom In and Zoom Out buttons I get the following error:Error: Object doesn't support property or method 'activate'Can anyone see any issues with the code below?Peter<!DOCTYPE html>
<html>
<head>
<!--The viewport meta tag is used to improve the presentation and behavior of the samples on iOS devices-->
<title>Navigation toolbar</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css">
<style>
@import "http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css";
.zoominIcon { background-image:url(images/nav_zoomin.png); width:16px; height:16px; }
.zoomoutIcon { background-image:url(images/nav_zoomout.png); width:16px; height:16px; }
.zoomfullextIcon { background-image:url(images/nav_fullextent.png); width:16px; height:16px; }
.zoomprevIcon { background-image:url(images/nav_previous.png); width:16px; height:16px; }
.zoomnextIcon { background-image:url(images/nav_next.png); width:16px; height:16px; }
.panIcon { background-image:url(images/nav_pan.png); width:16px; height:16px; }
.deactivateIcon { background-image:url(images/nav_decline.png); width:16px; height:16px; }
</style>
<script> var dojoConfig = { parseOnLoad: false,
packages: [
location: location.pathname.replace(/\/[^/]+$/, '') + '/ERMWidgets'
</script>
<script src="http://js.arcgis.com/3.7/"></script>
<script>
var map;
require([
"esri/map",
"dojo/parser",
"esri/dijit/BasemapGallery",
"esri/toolbars/navigation",
"esri/arcgis/utils",
"ERMWidgets/ZoomToXY",
"dojo/dom",
"dijit/form/TextBox",
"dijit/form/Button",
"dijit/Toolbar",
"dijit/layout/BorderContainer",
"dijit/layout/ContentPane",
"dijit/layout/AccordionContainer",
"dojo/domReady!"
], function (Map, parser, BasemapGallery, Navigation, arcgisUtils, ZoomToXY) {
parser.parse();
map = new Map("map", {
basemap: "satellite",
center: [-56.953, 57.472],
zoom: 3
var basemaps = [];
//Basemap 1
var oceanLayer = new esri.dijit.BasemapLayer({ url: "http://services.arcgisonline.com/ArcGIS/rest/services/Ocean_Basemap/MapServer" });
var OceanBasemap = new esri.dijit.Basemap({ layers: [oceanLayer], title: "ESRI Oceans Basemap", thumbnailUrl: "images/ocean.png" });
basemaps.push(OceanBasemap);
//Basemap 2
var imageryLayer = new esri.dijit.BasemapLayer({ url: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer" });
var ImageryBasemap = new esri.dijit.Basemap({ layers: [imageryLayer], title: "World Imagery", thumbnailUrl: "images/imagery.png" });
basemaps.push(ImageryBasemap);
//Basemap 3
var physicalLayer = new esri.dijit.BasemapLayer({ url: "http://services.arcgisonline.com/ArcGIS/rest/services/World_Physical_Map/MapServer" });
var PhysicalBasemap = new esri.dijit.Basemap({ layers: [physicalLayer], title: "Physical Imagery", thumbnailUrl: "images/physical.png" });
basemaps.push(PhysicalBasemap);
var basemapGallery = new esri.dijit.BasemapGallery({ showArcGISBasemaps: false, basemaps: basemaps, map: map }, "basemapGallery");
basemapGallery.startup();
basemapGallery.on("error", function (msg) {
console.log("basemap gallery error: ", msg);
var navToolbar = new Navigation(map);
navToolbar.on("extent-history-change", extentHistoryChangeHandler);
function extentHistoryChangeHandler() {
dijit.byId("zoomprev").disabled = navToolbar.isFirstExtent();
dijit.byId("zoomnext").disabled = navToolbar.isLastExtent();
newXY = new ZoomToXY({
map: map
}, dojo.byId('zoomXYDiv'));
newXY.startup();
</script>
</head>
<body class="claro">
<div id="mainWindow" data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width:100%;height:100%;">
<div id="header" data-dojo-type="dijit.layout.ContentPane" region="top">
<div id="navToolbar" data-dojo-type="dijit.Toolbar">
<div data-dojo-type="dijit.form.Button" id="zoomin" data-dojo-props="iconClass:'zoominIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.ZOOM_IN);}">Zoom In</div>
<div data-dojo-type="dijit.form.Button" id="zoomout" data-dojo-props="iconClass:'zoomoutIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.ZOOM_OUT);}">Zoom Out</div>
<div data-dojo-type="dijit.form.Button" id="zoomfullext" data-dojo-props="iconClass:'zoomfullextIcon', onClick:function(){navToolbar.zoomToFullExtent();}">Full Extent</div>
<div data-dojo-type="dijit.form.Button" id="zoomprev" data-dojo-props="iconClass:'zoomprevIcon', onClick:function(){navToolbar.zoomToPrevExtent();}">Prev Extent</div>
<div data-dojo-type="dijit.form.Button" id="zoomnext" data-dojo-props="iconClass:'zoomnextIcon', onClick:function(){navToolbar.zoomToNextExtent();}">Next Extent</div>
<div data-dojo-type="dijit.form.Button" id="pan" data-dojo-props="iconClass:'panIcon', onClick:function(){navToolbar.activate(esri.toolbars.Navigation.PAN);}">Pan</div>
<div data-dojo-type="dijit.form.Button" id="deactivate" data-dojo-props="iconClass:'deactivateIcon' ,onClick:function(){navToolbar.deactivate();}">Deactivate</div>
<div data-dojo-type="dijit.form.DropDownButton" id="zoomXYButton" data-dojo-props="iconClass:'dijitIconEdit'"><span>Zoom to XY</span>
<div data-dojo-type="dijit.TooltipDialog"><div id="zoomXYDiv"></div></div> </div>
</div>
</div>
<div id="rightPane" data-dojo-type="dijit.layout.ContentPane" region="right" style="width:25%">
<div data-dojo-type="dijit.layout.AccordionContainer">
<div data-dojo-type="dijit.layout.ContentPane" id="layerControlPane" title="LayerControl" selected="true" >
This pane will contain the layer control functions.
</div>
<div data-dojo-type="dijit.layout.ContentPane" id="legendPane" title="Legend" >
This pane will contain the legend.
</div>
<div data-dojo-type="dijit.layout.ContentPane" id="basemapPane" title="Select Basemap" >
<div id="basemapGallery"></div>
</div>
<div data-dojo-type="dijit.layout.ContentPane" id="metadataPane" title="Metadata" >
This pane will contain metadata information.
</div>
<div data-dojo-type="dijit.layout.ContentPane" id="analysisPane" title="Analysis" >
This pane will contain data analysis functions.
</div>
</div>
</div>
<div id="map" style="width:100%; height:512px; top:200px" region="center">
</div>
</div>
</div>
</body>
</html>
