I am coming across a problem when I try to create editable feature services for use in ArcGIS Online maps.
I have attempted to upload my data a couple of different ways.
First, I uploaded a zipped shapefile of points. It successfully showed published and I was able to turn on the editing capabilities in the Item Description. I can add it to a map and view the points. I can choose edit and attempt to place a point, however when I do - nothing happens. It almost seems like the point is there as the "UNDO" button becomes active, but there is no placed point. When I check the attribute table the record was not created.
I then tried uploading a zipped shapefile of line features. Same issue. I can see myself drawing the line, but when I double click to finish the edit has not been applied.
Lastly, I tried uploading directly from ArcGIS desktop to a hosted service both my point file and line file in a geodatabase. Same editing issue.
I've checked to make sure editing capbilities are full, I've allowed sync, I've chose "Open in map will full editing capabilities." Nothing is working.
This is definitely a "new to me" issue as I've previously had success in uploading editable features. But yesterday and today this would not work.
You may be running into a recent bug here. Could you try republishing your hosted feature service from ArcGIS Desktop, but disable "Sync" as an allowable operation in the Feature Access capabilities window and see if edits can be registered then?
Thomas
