<script>var dojoConfig = { parseOnLoad:true }</script> <script src="http://js.arcgis.com/3.7/"></script> <script> dojo.require("esri.map"); dojo.require("dojox.grid.DataGrid"); dojo.require("dojo.data.ItemFileReadStore"); dojo.require("esri.tasks.find"); dojo.require("dijit.layout.BorderContainer"); dojo.require("dijit.layout.ContentPane"); dojo.require("dijit.form.Button"); dojo.require("esri.dijit.Legend"); dojo.require("esri.InfoTemplate"); var findTask, findParams; var map, center, minScale, zoom; var grid, store; function init() { dojo.connect(grid, "onRowClick", onRowClickHandler); center = [-98.495, 29.42]; zoom = 13; map = new esri.Map("map", { basemap: "streets", center: center, zoom: zoom }); var transMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer", { id: "trans", minScale: "4500", opacity: "0.5" }); var mainMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mapservices2.bexar.org/arcgis/rest/services/Historic/Historic_POI/MapServer", { id: "1896" }); map.addLayers([transMapLayer, mainMapLayer]); //Create Find Task using the URL of the map service to search findTask = new esri.tasks.FindTask("http://mapservices2.bexar.org/arcgis/rest/services/Historic/Historic_POI/MapServer"); dojo.connect(map, "onLoad", function() { //Create the find parameters findParams = new esri.tasks.FindParameters(); findParams.returnGeometry = true; findParams.layerIds = [0]; findParams.searchFields = [ "Name", "Owner", "Category", "Type1", "Type2", "Type3"]; findParams.outSpatialReference = map.spatialReference; console.log("find sr: ", findParams.outSpatialReference); }); dojo.connect(map, "onLayersAddResult", function(result) { var legend = new esri.dijit.Legend({ map:map, layerInfos:[{layer:mainMapLayer,title:"Points of Interest"}], arrangement:esri.dijit.Legend.ALIGN_RIGHT },"legendDiv"); legend.startup(); }); } function doFind() { //Set the search text to the value in the box findParams.searchText = dojo.byId("ownerName").value; findTask.execute(findParams,showResults); } function showResults(results) { //This function works with an array of FindResult that the task returns map.graphics.clear(); var symbol = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 25, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([255, 0, 0]), 1), new dojo.Color([0, 255, 0, 0.25])); //create array of attributes var items = dojo.map(results,function(result){ var graphic = result.feature; graphic.setInfoTemplate(new esri.InfoTemplate( "Points of Interest", "<tr>Name:<td>${Name}</tr></td><br><tr>Category:<td>${Category}</tr></td><br><tr>Type 1:<td>${Type1}</tr></td><br><tr>Type 2:<td>${Type2}</tr></td><br><tr>Type 3:<td>${Type3}</tr></td><br><tr>Owner:<td>${Owner}</tr></td>")); graphic.setSymbol(symbol); map.graphics.add(graphic); return result.feature.attributes; }); //Create data object to be used in store var data = { identifier: "OBJECTID", //This field needs to have unique values label: "OBJECTID", //Name field for display. Not pertinent to a grid but may be used elsewhere. items: items }; //Create data store and bind to grid. store = new dojo.data.ItemFileReadStore({ data:data }); var grid = dijit.byId('grid'); grid.setStore(store); //Zoom back to the initial map extent map.centerAndZoom(center, zoom); } //Zoom to the parcel when the user clicks a row function onRowClickHandler(evt){ var clickedTaxLotId = grid.getItem(evt.rowIndex).OBJECTID; var selectedTaxLot; var distance = 100; dojo.forEach(map.graphics.graphics,function(graphic){ if((graphic.attributes) && graphic.attributes.OBJECTID === clickedTaxLotId){ selectedTaxLot = graphic.geometry; return; } }); var newExtent = new esri.geometry.Extent({ "xmin": selectedTaxLot.x - distance, "ymin": selectedTaxLot.y - distance, "xmax": selectedTaxLot.x + distance, "ymax": selectedTaxLot.y + distance, "spatialReference": { "wkid": 102100 } }); map.setExtent(newExtent); console.log(map.graphics.graphics); } dojo.ready(init); </script> </head> <body class="claro"> <div data-dojo-type="dijit.layout.BorderContainer" data-dojo-props="design:'headline'" style="width:100%;height:100%;margin:0;"> <div id="header" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'top'" style="border:1px solid #000;"> Bexar County Points of Interest 1896 (Beta) <div id="subheader"><a href="http://www.bexar.org/it/gis.html" target="_new">by Bexar County eServices GIS Group</a></div> </div> <div data-dojo-props="region:'left'" data-dojo-type="dijit.layout.ContentPane" data-dojo-props="title:'Legend'" style="width:19%; border:1px solid #000;"> <div id="legendDiv"></div> </div> <div id="map" data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane" style="border:1px solid #000;"> <div id="search"><b>Point of Interest:</b> <input type="text" id="ownerName" size="20" value="The Alamo" /> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFind();}, value:"Search"'> Search </button> <i>Any name, place, category, keyword, etc. Results will be highlighted on map and in table below map. Clicking on table row in table results will zoom to point of interest </i></div></div> <div data-dojo-type="dijit.layout.ContentPane" data-dojo-props="region:'bottom'" style="height:150px;"> <table data-dojo-type="dojox.grid.DataGrid" data-dojo-id="grid" id="grid" data-dojo-props="rowsPerPage:'5', rowSelector:'20px'"> <thead> <tr> <th field="Name" width="16%">Point of Interest</th> <th field="Category">Category</th> <th field="Owner">Owner</th> <th field="Type1">Type 1</th> <th field="Type2">Type 2</th> <th field="Type2">Type 3</th> </tr> </thead> </table> </div> </div> </body> </html>
Solved! Go to Solution.
var map, center, zoom, grid; function init() { center = [-98.495, 29.42]; zoom = 13; map = new esri.Map("map", { basemap: "streets", center: center, zoom: zoom }); var mainMapLayer = new esri.layers.ArcGISDynamicMapServiceLayer("http://mapservices2.bexar.org/arcgis/rest/services/Historic/Historic_POI/MapServer"); map.addLayers([mainMapLayer]); var legend = new esri.dijit.Legend({ map: map, layerInfos: [{layer:mainMapLayer,title:"Points of Interest"}], arrangement: esri.dijit.Legend.ALIGN_RIGHT },"legendDiv"); legend.startup(); map.on("click", identifyPOI); dojo.connect(grid, "onRowClick", onRowClickHandler); };
<div data-dojo-props="region:'center'" data-dojo-type="dijit.layout.ContentPane" style="border:1px solid #000;"> <div id="search"><b>Point of Interest:</b> <input type="text" id="ownerName" size="20" value="The Alamo" /> <button data-dojo-type="dijit.form.Button" data-dojo-props='onClick:function(){ doFind();}, value:"Search"'>Search</button> <i>Any name, place, category, keyword, etc. Results will be highlighted on map and in table below map. Clicking on table row in table results will zoom to point of interest </i> </div> <div id="map"></div> </div>
require([ "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "dojo/_base/array", "esri/InfoTemplate", "dojo/domReady!" ], function(Map, ArcGISDynamicMapServiceLayer, IdentifyTask, IdentifyParameters, array, InfoTemplate) { var map = new Map("map", { basemap: "gray", center: [-98.544, 29.47], zoom: 12 }); var layer = new ArcGISDynamicMapServiceLayer("http://mapservices2.bexar.org/arcgis/rest/services/Historic/Historic_POI/MapServer"); map.addLayer(layer); map.on("click", function(evt){ var identify = new IdentifyTask("http://maps1.arcgisonline.com/ArcGIS/rest/services/USA_Federal_Lands/MapServer"); var identifyParams = new IdentifyParameters(); identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.returnGeometry = true; identifyParams.tolerance = 3; map.infoWindow.clearFeatures(); identify.execute(identifyParams, function(results){ map.infoWindow.setFeatures(array.map(results, function(result){ var feature = result.feature; feature.setInfoTemplate(new InfoTemplate()); return feature; })); map.infoWindow.show(evt.mapPoint); }); }); });
require(["esri/map", "esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/domReady!"], function(Map, FeatureLayer, InfoTemplate) { var map = new Map("map", { basemap: "gray", center: [-87.5, 42], zoom: 11, }); var layer = new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/CTAStation/FeatureServer/0", { outFields: ["*"], infoTemplate: new InfoTemplate() }); map.addLayer(layer); });
There are several ways to get popup for your layer, depending on the type of your layer and how you want to handle it. Given the code you already have, you need to use IdentifyTask to get features with the point you click on the map:
(I clear the search part to make it cleaner, but you can integrate the code below with the search part you already have. Please also consider coding in the AMD style.)require([ "esri/map", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters", "dojo/_base/array", "esri/InfoTemplate", "dojo/domReady!" ], function(Map, ArcGISDynamicMapServiceLayer, IdentifyTask, IdentifyParameters, array, InfoTemplate) { var map = new Map("map", { basemap: "gray", center: [-98.544, 29.47], zoom: 12 }); var layer = new ArcGISDynamicMapServiceLayer("http://mapservices2.bexar.org/arcgis/rest/services/Historic/Historic_POI/MapServer"); map.addLayer(layer); map.on("click", function(evt){ var identify = new IdentifyTask("http://maps1.arcgisonline.com/ArcGIS/rest/services/USA_Federal_Lands/MapServer"); var identifyParams = new IdentifyParameters(); identifyParams.geometry = evt.mapPoint; identifyParams.mapExtent = map.extent; identifyParams.returnGeometry = true; identifyParams.tolerance = 3; map.infoWindow.clearFeatures(); identify.execute(identifyParams, function(results){ map.infoWindow.setFeatures(array.map(results, function(result){ var feature = result.feature; feature.setInfoTemplate(new InfoTemplate()); return feature; })); map.infoWindow.show(evt.mapPoint); }); }); });
A more elegant way we strongly recommend is to use FeatureLayer, which allows you to identify features without sending extra requests to the server:require(["esri/map", "esri/layers/FeatureLayer", "esri/InfoTemplate", "dojo/domReady!"], function(Map, FeatureLayer, InfoTemplate) { var map = new Map("map", { basemap: "gray", center: [-87.5, 42], zoom: 11, }); var layer = new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/CTAStation/FeatureServer/0", { outFields: ["*"], infoTemplate: new InfoTemplate() }); map.addLayer(layer); });
