datanetics
Help getting started
Discussion created by datanetics on Oct 23, 2013
Latest reply on Oct 25, 2013 by JGravois-esristaff
Should the samples work if you just copy to the www root directory. Normally we are a Flex shop but need to move to JAVA. I downloaded the JAVA API and SDK and followed the directions. I tried the test install code and the map is blank. Figuring I missed something in the install instructions I tried just loading a few of the samples to the www root dir that call everything from ArcGIS and still a blank map. Any help would be appreciated.
Outcomes
