nmolnar
ExportMetadata_conversion does not work in ArcGIS Server 10.1
Discussion created by nmolnar on Oct 22, 2013
Latest reply on Oct 23, 2013 by nmolnar
When I try to use the ExportMetadata_conversion function via arcpy in a processing script on Server (Linux), I get the following error: ExecuteError: Failed to execute. Parameters are not valid. ERROR 000816: The tool is not valid. Failed to execute (ExportMetadata).
This appears to be related to this long-standing issue: http://forums.arcgis.com/threads/744...ssing-metadata
However, the workaround mentioned in that thread won't work here because 1) I can't install Desktop on linux to get the DLLs, and 2) If I copy the DLLs from Desktop elsewhere, they'd be 32-bit and Server is now 64-bit only (right?)
Any other ideas for a workaround? Is this issue actually fixed in 10.2? Will it ever be fixed?
_Nik
Outcomes
