john@haasbeek.com
Nav Toolbar Compatibility Problems in IE10
Discussion created by john@haasbeek.com on Oct 16, 2013
Latest reply on Jan 4, 2014 by amarsden
Try the nav toolbar sample from the API samples page in IE10.  The zoom in and zoom out work but do not display a marquee rectangle as you click and drag.
Found this problem in my own code using the nav toolbar and tried the meta tag:
<meta http-equiv="X-UA-Compatible"  content="IE=9" />
This became even wierder - the rectangle would display correctly the first time i zoomed but after that the zoom cursor would stay at the original click location as the rectangle expanded while I dragged, and the map in the background was panning as I dragged.  The zoom would then work but it was ugly.  Same behavior with content="IE=8".
Not sure what other incompatibilities I will find but this is very disconcerting.  Anyone out there got a workaround or an alternative solution?
Cheers,
JH
Outcomes
