sqlldr / st_geometry wkt
4160
5
10-16-2013 01:46 PM
runegullstrom
it should be possible to load wkt data into st_geometry with sql loader (oracle). I can't get it working though,
does anybody have an example?
regards,
Rune
oracle 11g / sde10
runegullstrom
Maybe some more detail would be helpful:
if my table is this:
CREATE TABLE GEOMETRY_TEST
  GID  INTEGER,
  G1   SDE.ST_GEOMETRY
And my sql loader ctl script is this:
LOAD DATA
INFILE *
TRUNCATE
INTO TABLE geometry_test
FIELDS TERMINATED BY '|'
OPTIONALLY ENCLOSED BY '"'
TRAILING NULLCOLS (
gid,
G1 EXPRESSION "sde.st_geomfromtext(':g1',0)"
BEGINDATA
1|"POINT  ( 10.02000000 20.01000000),0"
2|"POINT  ( 11.02000000 20.01000000),0"
Then I'm getting this back in my .log file:
Record 1: Rejected - Error on table GEOMETRY_TEST, column G1.
ORA-20003: Geometry type "" is not a valid shape type.
ORA-06512: at "SDE.ST_GEOM_UTIL", line 213
ORA-06512: at "SDE.ST_GEOMFROMTEXT", line 20
I've tried all kind of permutations but sofar without any luck,
regards,
SachinKanaujia
Occasional Contributor III
First try to validate the following
1) Setup is correct using the following query
select sde.ST_AsText(SDE.ST_Geometry('POINT (10 10)', 0)) from dual;
2) You are able to create a table independently with the ST_GEOMETRY column
GID INTEGER,
G1 SDE.ST_GEOMETRY
3) I did not understand why you are using 0 at both the places?
G1 EXPRESSION "sde.st_geomfromtext(':g1',0)"  <--- here
BEGINDATA
1|"POINT ( 10.02000000 20.01000000),0" <-- here
2|"POINT ( 11.02000000 20.01000000),0" <-- here
Try with this
1|"POINT ( 10.02000000 20.01000000)"
2|"POINT ( 11.02000000 20.01000000)"
VinceAngelo
Esri Esteemed Contributor
I think Sachin nailed it -- the trailing ",{SRID}" is not a part of the WKT specification
(even if some implementations of OGC ST_GEOMETRY do support it as an extension).
You really ought to specify an explicit SRID, not a default one.  This may help prevent
significant difficulties after the data is loaded.
- V
runegullstrom
I use the '0' because sde.st_geomfromtext requires the srid to be defined*
*http://resources.arcgis.com/en/help/main/10.1/index.html#/ST_GeomFromText/006z00000054000000/
Leaving it out results in this message in the sqlloader log:
ORA-06553: PLS-306: wrong number or types of arguments in call to 'ST_GEOMFROMTEXT'
Still puzzled about how to do this,
regards,
Rune
VinceAngelo
Yes, an SRID is required, but it should be the correct SRID, and it must be *outside* the
WKT string, as in the example above (you must hard-code the SRID in the control file).
The constructor takes two arguments, a string/CLOB, and an integer.  Having the integer
inside the string won't work and neither will leaving it out.
- V
