MultiPatch to KML - No Textures in ArcGlobe
1808
10-16-2013 02:36 AM
CarlBester
Hi all,
I have received some photo-realistic building multipatches. The aim is to create an "As-is" model of the entire city as a sort of 3D basemap, so the format should be able to handle huge datasets. I then want to serve the "3D basemap" from ArcGlobe as a GlobeService.
Question #1: Should I convert the multipatches to KML? Which 3D format handles a large number of features the best?
I have tried to convert the textured multipatches to KML, but when it opens in ArcGLobe the textures are missing. I then tried to generate simple Shape rule models of the multipatches as described in http://forums.arcgis.com/threads/76669-Shapes-VS.-Models-VS.-MultiPatch before exporting to KML.
Shape -->
    Shape.
But the buildings still do not have textures.
I then tried to export procedurally generated and textured buildings to KML and view it in ArcGlobe and it worked!
I used the default ArcGLobe settings in the Export window for all attempts.
Question #2: Is there another way to export Multipatches (as well as their textures) to a KML?
Any advice would be greatly appreciated.
Carl
MatthiasBuehler1
Hi ..
Is there a reason, why you are even converting to KML? ArcGLobe can display textured multipatches, no problem. You can also turn these multipatches into a Globe service as well.
So there's no real use for CityEngine in this case..
Let me know !
Matt
