AnsweredAssumed Answered
Re: Radio buttons work fine with Dynamic layers but not with feature layers
Question asked by eogriffin79 on Oct 14, 2013
Latest reply on Oct 15, 2013 by eogriffin79
Hi
I have modified a piece of code originally used here: http://developers.arcgis.com/en/javascript/sandbox/sandbox.html?sample=layers_web_tiled
It works absolutely fine with dynamic layers but not with feature layers. With feature layers I can use the radio buttons once i.e. turn all the layers on, but then none of the layers turn off again.
Code:
[HTML]<script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("esri.map");
   dojo.require("esri.arcgis.utils");
   dojo.require("esri.layers.ArcGISDynamicMapServiceLayer");
      var map;
      function init() {
  var initialExtent = new esri.geometry.Extent({"xmin": 1089971.6232999992,"ymin":4748140.810900001,"xmax":2089534.8891000012,"ymax": 6194292.3109,"spatialReference":{"wkid":2193}});
  map = new esri.Map("map", {extent:initialExtent});
        var layers = [{
  "options":{
  "id": "Healthy", "visible": true
  "url": "https://aserver/arcgis/rest/services/NZHS/Indicator4/MapServer"
  "options":{
  "id": "Mental", "visible": false
  "url": "https://aserver/arcgis/rest/services/NZHS/Indicator2/MapServer"
  "options":{
  "id": "Active", "visible": false
  "url": "https://aserver/arcgis/rest/services/NZHS/Indicator3/MapServer"
        // clear out the side bar
        dojo.byId("leftPane").innerHTML = "";
        // create and add the layers
        var layerDiv = dojo.create("div");
        dojo.forEach(layers, function(l) {
          var lyr = new esri.layers.ArcGISDynamicMapServiceLayer(l.url, l.options);
          map.addLayer(lyr);
          // add a radio button for the layer
          dojo.create("input", {
            "type": "radio",
            "checked": l.options.visible,
            "name": "tiledLayers",
            "id": l.options.id,
            "value": l.options.id
          }, layerDiv);
          // then a label
          dojo.create("label", {
            "for": l.options.id,
            "innerHTML": l.options.id + "<br />"
          }, layerDiv);
        // add the radio buttons to the page
        dojo.place(layerDiv, dojo.byId("leftPane"));
        // event delegation to toggle layers
        dojo.connect(dojo.byId("leftPane"), "onclick", toggleLayer);
      function toggleLayer(e) {
        console.log("clicked: ", e, dojo.byId(e.target.id));
        if ( ! dojo.byId(e.target.id) ) {
          // return if we cannot find the DOM node for a layer
          return;
        // hide other layers
        dojo.forEach(map.layerIds, function(id) {
          map.getLayer(id).hide();
        // show the layer with the clicked radio button
        var layer = map.getLayer(e.target.id);
        layer.show();
     //show map on load
      dojo.ready(init);[/HTML]
Is there any reason why it should be doing this? Is it due to feature layers being driven client side? How can I fix it?
Cheers
Ed
Outcomes
