Hi,I have a table named "street" with a column named "Kategorie", filled with values "0..6". I added a new column named "RULE". I want to fill this column with strings depending on "KATEGORIE". I have a PY-Script and it doesn't work. What is wrong.I think the problem is the line "expression" or "codeblock". I try to print the result of "myval".The result is a error message "name myval is not defined"Thank you for your help !
expression = "getKat(!KATEGORIE!)"
codeblock = """def getKat(KATEGORIE):
if KATEGORIE == "0":
myval == "Autobahn"
elif KATEGORIE == "1":
myval == "Bundesstrasse"
else:
myval == "3"
return myval"""
print "myval", myval
arcpy.CalculateField_management(ERG, "RULE", expression, "PYTHON", codeblock)
