gprocino
enterprise geodatabase on oracle spatial with linux
Discussion created by gprocino on Oct 10, 2013
Hi all,
I will create for my customer an enterprise geodatabase where AGD 10.1 clients has a direct connection to an enterprise geodatabase oracle spatial with SDO_Geometry datatype.
The customer has the following server:
1) db server with Oracle 10g R2 (64-bit) 10.2.0.3 - SO: linux red hat enterprise a 64bit release 4
2) db server with Oracle 11g R2 (64-bit) 11.2.0.1 - SO: linux red hat enterprise a 64bit release 5.5
3) server with ags10.1 - SO: Window Server 2003 R2
What i need to install on db server, if I will use AGD 10.1 clients with direct connection so I will use arctoolbox command for create an enterprise geodatabase oracle spatial-gdo_geometry based? (http://resources.arcgis.com/en/help/main/10.1/index.html#/A_quick_tour_of_setting_up_a_geodatabase_in_Oracle/002n00000001000000/)
On Which SO I can create the enterprise geodatabase oracle spatial-gdo_geometry based with a direct connection? they are the some of ARCGIS Server 10.1 of the following page http://resources.arcgis.com/en/help/system-requirements/10.1/index.html#/Oracle_Database_Requirements/01510000006s000000/
where I read Red Hat Enterprise Linux AS/ES 5 (64-bit)  Update 7?
Thanks in advance.
Giuseppe P.
Outcomes
