I've some code that worked fine before I started moving to AMD style. Now, I'm getting an unexpected token error (in Native code, no less) when making my geoprocessing call. It fails immediately - that is, it doesn't even seem to get sent to the server. My geoprocessing tool is working fine, as I test that with the same parameters being sent from code, and I get the expected result. I've checked all the parameters being sent from code, and the token the error message indicates is not present in any of the parameters. How do I determine where the error is being introduced?My code:
var vl = JSON.stringify(_this.visibleLayers);
var params = {
"xMin": this.extent.xmin,
"yMin": this.extent.ymin,
"xMax": this.extent.xmax,
"yMax": this.extent.ymax,
"Spatial_Reference": this.spatRef.wkid,
"Map_Scale": this.mapScale,
"Visiblelayers": vl,
"Layout": this.layout,
"Map_Title": registry.byId("mapTitle").value,
"PointGraphics": graph.getFeatureSet("point"),
"LineGraphics": graph.getFeatureSet("polyline"),
"PolyGraphics": graph.getFeatureSet("polygon")
this.cmgp.submitJob(params, lang.hitch(this, this.pdfCompleteCallbackCM), lang.hitch(this, this.pdfStatusCallback), lang.hitch(this, this.pdfErrorCallback));
