efriveral1113
Cut a large polygon fail
Discussion created by efriveral1113 on Oct 9, 2013
Hi, I am developing a web application to edit polygons of land. I am using the example of the widget editor https://developers.arcgis.com/en/javascript/jssamples/ed_editing_widget.html link. When users try to cut a large polygon, the process fails. By contrast, the polygon retains its original shape. The polygon is consumed through a rest service that works for direct connection to Oracle. I appreciate if you can colaborarme with a solution to the problem.
Outcomes
