I have created and published a composite geocoder to server 10.2. The composite references a dual range Address centerline geocoder and a Single House Address point geocoder. When searching for an intersection using the composite, the results are returned with the correct street names, but the suffix type and city are duplicated - Walnut Street Street & Hickory Street Street, City, City. When looking at the REST results the composite fields for SufType1 and SufType2 both contain the duplicated value of 'Street Street'.
Can anyone suggest how to correct this? Is this expected behavior for intersection results from a composite geocoder?
Any help would be appreciated.
I use a composite locator myself with the same styles you use and I don't have this problem. Do you need both SufType1 and Suftype2?
