AnsweredAssumed Answered
Attributes from results of identify task do not show in popup
Question asked by bethdavis on Oct 7, 2013
Latest reply on Oct 8, 2013 by bethdavis
I am using an identify task on layers in a dynamic map service, and displaying the results in a popup.  I have nearly identical code working perfectly for another service, but with this case, the only the template I defined shows in the popup.  The identify does not seem to be pulling the attribute values to populate the fields in the popup.  Any suggestions?
ETA: here is a fiddle.
function mapReady(map){    on(map,"Click",executeIdentifyTask);    //create identify tasks and setup parameters     identifyTask = new esri.tasks.IdentifyTask("http://nmbbmapping.org/arcgis/rest/services/casa/MapServer/");            identifyParams = new esri.tasks.IdentifyParameters();    identifyParams.tolerance = 10;    identifyParams.returnGeometry = true;    identifyParams.layerIds = [1,16];    identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;    identifyParams.width  = map.width;    identifyParams.height = map.height;   }          function executeIdentifyTask(evt) {    identifyParams.geometry = evt.mapPoint;    identifyParams.mapExtent = map.extent;            var deferred = identifyTask.execute(identifyParams);     deferred.addCallback(function(response) {         // response is an array of identify result objects        // Let's return an array of features.     return dojo.map(response, function(result) {      var feature = result.feature;      feature.attributes.layerName = result.layerName;     if(result.layerName === 'Public Schools K12'){       //console.log(feature.attributes.PARCELID);       var template = new PopupTemplate ({        title: "Public Schools K12",        //description: ,        fieldInfos: [{ // define field infos to specify alias         fieldName: "INST_NAME",         visible: true,         label: "Institution Name: "        }, {         fieldName: "ADDRESS",         visible: true,         label: "Address: "        }, {         fieldName: "CITY",         visible: true,         label: "City: "        }]       });      feature.setInfoTemplate(template);     }      else if (result.layerName === 'Non Government Community Support'){       //console.log(feature.attributes.PARCELID);       var template = new PopupTemplate ({        title: "Non Government Community Support",        //description: ,        fieldInfos: [{ // define field infos to specify alias         fieldName: "INST_NAME",         visible: true,         label: "Institution Name: "        }, {         fieldName: "ADDRESS",         visible: true,         label: "Address: "        }, {         fieldName: "CITY",         visible: true,         label: "City: "        }]       });      feature.setInfoTemplate(template);     }   return feature;   });   });          map.infoWindow.setFeatures([ deferred ]);         map.infoWindow.show(evt.mapPoint);       }
Outcomes
