Solved! Go to Solution.
So it sounds like what is happening in my apps is option B described above. If services.arcgisonline.com was upgraded to 10.1 and CORS enabled then I would not get this error, right?
XMLHttpRequest cannot load http://services.arcgisonline.com/ArcGIS/rest/info?f=json. Origin http://developers.arcgis.com is not allowed by Access-Control-Allow-Origin. (ind
And if I am reading you right, the danger with setting "esri.config.defaults.io.corsDetection = false" in my apps is that I am now not checking ANY server I connect to with CORS, and with the big idea that everybody should be enabling CORS on their servers, this is not a good thing.
I'm sure it is out of your control, but if my second assumption is true, then Esri really should be upgrading services.arcgisonline.com, especially with it now two versions out of date. But I don't blame you guys, the upgrade from 10.0 to 10.1 is really a pain.
Next time we get asked by our rep why we are not on 10.2 (or why it took over a year to get to 10.1), I will point them to services.arcgisonline.com 😉
