Is it possible to administer ArcSDE Service from other machines
806
5
10-05-2013 08:14 AM
SteveS
Is it possible to administer ArcSDE Service from other machines(Client and not from the Server). ArcSDE is on SQL Server.
-We have to Start/Restart the ArcSDE Service from client machine. Is it possible to do it from any machines other than Server. (Either through GUI or Script/.bat file)
-I came across a document regarding scheduling ArcGIS Server service.
http://support.esri.com/es/knowledgebase/techarticles/detail/15929
Can I follow that document for scheduling ArcSDE Service.
-Previously I had used Putty on ArcSDE for Oracle. Will putty work for ArcSDE on SQL Server.
Steve
VinceAngelo
Esri Esteemed Contributor
No, you can't use PuTTY on a Windows host, but you can use Remote Desktop,
and you can configure the service for remote start, and you can abandon use
of application servers in favor of Direct Connect.
- V
SteveS
Vince,
Thanks for your response and suggestions. We have to restart the ArcSDE Service at 3AM(schedule). Can I use the command which you had mentioned (Starting a remote ArcSDE service on Windows) to schedule it. Is there any other scripts or commands to schedule it.
Steve
VinceAngelo
A google on "schedule commands on windows" should address this, though
I've never seen a need for daily service restart (that seems excessive).
- V
SteveS
Vince,
I found some articles regarding scheduling commands on windows. However it applies scheduling within the server and in our case, we have to schedule it from a client machine. Any suggestions.
Thanks for your help!
VinceAngelo
You've got a way to submit remote commands and a way to execute those
commands according to the clock.  The only thing I can add is to make sure
you put a delay between the shutdown and the start (at least 10-15 seconds)
so that the start doesn't fail due to incomplete shutdown.
Oh, and I should also recommend you abandon application server connections
again, since they're difficult to use at 10.1/10.2 and will be unavailable at the
next major release.
- V
