<!DOCTYPE html> <html> ], function( Map,Draw, BasemapGallery, arcgisUtils, Edit, Graphic, ArcGISTiledMapServiceLayer, FeatureLayer, AttributeInspector, Query, QueryTask, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol, Color, TemplatePicker, esriConfig, jsapiBundle, arrayUtils, parser, domConstruct, Button, keys, event, lang, registry, borderContainer, contentPane, titlePane, dom, on ) { parser.parse(); // snapping is enabled for this sample - change the tooltip to reflect this jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start + "<br>Press <b>ALT</b> to enable snapping"; // refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html esriConfig.defaults.io.proxyUrl = "/proxy"; esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tfsgis-iisd01:6080/arcgis/rest/services/Utilities/Geometry/GeometryServer"); map = new Map("map", { basemap: "hybrid", center: [-98.57, 30.98], zoom: 6, slider: true }); map.on("layers-add-result", initEditing); map.on("layers-add-result", initSelectToolbar); var ActivityArea = new FeatureLayer("http://tfsgis-iisd01:6080/arcgis/rest/services/MyMapService2/FeatureServer/1",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); var ActivityPoint = new FeatureLayer("http://tfsgis-iisd01:6080/arcgis/rest/services/MyMapService2/FeatureServer/0",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); var stewardship = new FeatureLayer("http://tfsgis-iisd01:6080/arcgis/rest/services/MyMapService2/FeatureServer/2",{ mode: FeatureLayer.MODE_ONDEMAND, outFields: ['*'] }); var selectionSymbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol( "solid", new Color("yellow"), 2 ), null ); stewardship.setSelectionSymbol(selectionSymbol); stewardship.on("edits-complete", function() { }); map.addLayers([ActivityArea,ActivityPoint,stewardship]); function initSelectToolbar(evt) { var stewardship = evt.layers[0].layer; var selectQuery = new Query(); map.on("click", function(evt) { selectQuery.geometry = evt.mapPoint; stewardship.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) { if (features.length > 0) { //store the current feature updateFeature = features[0]; map.infoWindow.setTitle(features[0].getLayer().name); map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)); } else { map.infoWindow.hide(); } }); }); map.infoWindow.on("hide", function() { stewardship.clearSelection(); }); var layerInfos = [{ 'featureLayer': stewardship, 'showAttachments': false, 'isEditable': true, 'fieldInfos': [ {'fieldName': 'Office', 'isEditable':true, 'tooltip': 'Current Status', 'label':'Status:'}, {'fieldName': 'Forester', 'isEditable':true, 'tooltip': 'The name of this oil field', 'label':'Field Name:'}, {'fieldName': 'PlanID', 'isEditable':false,'label':'Acreage:'}, {'fieldName': 'Status', 'isEditable':false, 'label':'Average Depth:'}, {'fieldName': 'DateStart', 'isEditable':false, 'label':'Cummulative Oil:'}, ] }]; var attInspector = new AttributeInspector({ layerInfos:layerInfos }, domConstruct.create("div")); //add a save button next to the delete button var saveButton = new Button({ label: "Save", "class": "saveButton"}); domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after"); saveButton.on("click", function(){ updateFeature.getLayer().applyEdits(null, [updateFeature], null); }); attInspector.on("attribute-change", function(evt) { //store the updates to apply when the save button is clicked updateFeature.attributes[evt.fieldName] = evt.newFieldValue; }); attInspector.on("next", function(evt) { updateFeature = evt.feature; console.log("Next " + updateFeature.attributes.objectid); }); attInspector.on("delete", function(evt){ evt.feature.getLayer().applyEdits(null,null,[feature]); map.infoWindow.hide(); }); map.infoWindow.setContent(attInspector.domNode); map.infoWindow.resize(350, 240); } function initEditing(evt) { console.log("initEditing", evt); // var map = this; var currentLayer = null; var layers = arrayUtils.map(evt.layers, function(result) { return result.layer; }); console.log("layers", layers); var editToolbar = new Edit(map); editToolbar.on("deactivate", function(evt) { currentLayer.applyEdits(null, [evt.graphic], null); }); arrayUtils.forEach(layers, function(layer) { var editingEnabled = false; layer.on("dbl-click", function(evt) { event.stop(evt); if (editingEnabled === false) { editingEnabled = true; editToolbar.activate(Edit.EDIT_VERTICES , evt.graphic); } else { currentLayer = this; editToolbar.deactivate(); editingEnabled = false; } }); layer.on("click", function(evt) { event.stop(evt); if (evt.ctrlKey === true || evt.metaKey === true) { //delete feature if ctrl key is depressed layer.applyEdits(null,null,[evt.graphic]); currentLayer = this; editToolbar.deactivate(); editingEnabled=false; } }); }); var templatePicker = new TemplatePicker({ featureLayers: layers, rows: "auto", columns: 2, grouping: true, style: "height: auto; overflow: auto;" }, "templatePickerDiv"); templatePicker.startup(); var drawToolbar = new Draw(map); var selectedTemplate; templatePicker.on("selection-change", function() { if( templatePicker.getSelected() ) { selectedTemplate = templatePicker.getSelected(); } switch (selectedTemplate.featureLayer.geometryType) { case "esriGeometryPoint": drawToolbar.activate(Draw.POINT); break; case "esriGeometryPolyline": drawToolbar.activate(Draw.POLYLINE); break; case "esriGeometryPolygon": drawToolbar.activate(Draw.POLYGON); break; } }); drawToolbar.on("draw-end", function(evt) { drawToolbar.deactivate(); editToolbar.deactivate(); var newAttributes = lang.mixin({}, selectedTemplate.template.prototype.attributes); var newGraphic = new Graphic(evt.geometry, null, newAttributes); selectedTemplate.featureLayer.applyEdits([newGraphic], null, null); }); } });// end require </script> </head> <body class="claro"> <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;"> <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'"> Spatial Accomplishment Report System </div> <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;"> <div id="templateDiv"></div> <div id="templatePickerDiv"></div> <br /> <br /> <div> <button id="button">Calculate</button> </div> <div id="info" style="padding:5px; margin:5px; background-color:#eee; height:680px;">
Solved! Go to Solution.
map.on("layers-add-result", layersAddResultHandler); function layersAddResultHandler(evt) { //initEditing code console.log("initEditing", evt); // var map = this; var currentLayer = null; var layers = arrayUtils.map(evt.layers, function(result) { return result.layer; }); console.log("layers", layers); //etc //initSelectToolbar code var stewardship = evt.layers[0].layer; var selectQuery = new Query(); //etc. }
require([ "esri/map", "esri/layers/FeatureLayer", "esri/dijit/AttributeInspector", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleFillSymbol", "dojo/_base/Color", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/config", "esri/tasks/query", "dojo/parser", "dojo/dom-construct", "dijit/form/Button", "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!" ], function( Map, FeatureLayer, AttributeInspector, SimpleLineSymbol, SimpleFillSymbol, Color, ArcGISDynamicMapServiceLayer, esriConfig, Query, parser, domConstruct, Button ) { parser.parse(); // refer to "Using the Proxy Page" for more information: https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html esriConfig.defaults.io.proxyUrl = "/proxy"; map = new Map("mapDiv", { basemap: "streets", center: [-97.395, 37.537], zoom: 11 }); map.on("layers-add-result", initSelectToolbar); var petroFieldsMSL = new ArcGISDynamicMapServiceLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSFields/MapServer"); petroFieldsMSL.setDisableClientCaching(true); map.addLayer(petroFieldsMSL); var petroFieldsFL = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Petroleum/KSFields/FeatureServer/0", { mode: FeatureLayer.MODE_SELECTION, outFields: ["approxacre","objectid","field_name","activeprod","cumm_oil","cumm_gas","avgdepth"] }); var selectionSymbol = new SimpleFillSymbol( SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol( "solid", new Color("yellow"), 2 ), null ); petroFieldsFL.setSelectionSymbol(selectionSymbol); petroFieldsFL.on("edits-complete", function() { petroFieldsMSL.refresh(); }); map.addLayers([petroFieldsFL]); function initSelectToolbar(evt) { var petroFieldsFL = evt.layers[0].layer; var selectQuery = new Query(); map.on("click", function(evt) { selectQuery.geometry = evt.mapPoint; petroFieldsFL.selectFeatures(selectQuery, FeatureLayer.SELECTION_NEW, function(features) { if (features.length > 0) { //store the current feature updateFeature = features[0]; map.infoWindow.setTitle(features[0].getLayer().name); map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint)); } else { map.infoWindow.hide(); } }); }); map.infoWindow.on("hide", function() { petroFieldsFL.clearSelection(); }); var layerInfos = [{ 'featureLayer': petroFieldsFL, 'showAttachments': false, 'isEditable': true, 'fieldInfos': [ {'fieldName': 'activeprod', 'isEditable':true, 'tooltip': 'Current Status', 'label':'Status:'}, {'fieldName': 'field_name', 'isEditable':true, 'tooltip': 'The name of this oil field', 'label':'Field Name:'}, {'fieldName': 'approxacre', 'isEditable':false,'label':'Acreage:'}, {'fieldName': 'avgdepth', 'isEditable':false, 'label':'Average Depth:'}, {'fieldName': 'cumm_oil', 'isEditable':false, 'label':'Cummulative Oil:'}, {'fieldName': 'cumm_gas', 'isEditable':false, 'label':'Cummulative Gas:'} ] }]; var attInspector = new AttributeInspector({ layerInfos:layerInfos }, domConstruct.create("div")); //add a save button next to the delete button var saveButton = new Button({ label: "Save", "class": "saveButton"}); domConstruct.place(saveButton.domNode, attInspector.deleteBtn.domNode, "after"); saveButton.on("click", function(){ updateFeature.getLayer().applyEdits(null, [updateFeature], null); }); attInspector.on("attribute-change", function(evt) { //store the updates to apply when the save button is clicked updateFeature.attributes[evt.fieldName] = evt.newFieldValue; }); attInspector.on("next", function(evt) { updateFeature = evt.feature; console.log("Next " + updateFeature.attributes.objectid); }); attInspector.on("delete", function(evt){ evt.feature.getLayer().applyEdits(null,null,[feature]); map.infoWindow.hide(); }); map.infoWindow.setContent(attInspector.domNode); map.infoWindow.resize(350, 240); }
