AnsweredAssumed Answered
VBS 999999 Error
Question asked by riamuyabu on Oct 4, 2013
Latest reply on Oct 14, 2013 by riamuyabu
I have written a script for the model builder's calculate field function in VBScript but I keep getting the 999999 error.
I have gone over my code several times but cannot seem to find a reason for it not to be able to run.
INPUT TABLE: JOIN_CarData_RoadLinks
FIELD NAME: JOIN_CarData_RoadLinks.OrientationOfCar
EXPRESSION: CarOrientation
[PHP]
Dim CarOrientation
Dim RoadOrientation
RoadOrientation = [JOIN_CarData_RoadLinks.Orientation]
Dim RoadCompass
RoadCompass = [JOIN_CarData_RoadLinks.CompassA]
Dim RoadCompassMax
RoadCompassMax = RoadCompass + 170
If RoadCompassMax > 360 Then
RoadCompassMax = RoadCompassMax - 360
ElseIf RoadCompassMax < 0 Then
RoadCompassMax = RoadCompassMax + 360
End If
Dim RoadCompassMin
RoadCompassMin = RoadCompass - 170
If RoadCompassMin > 360 Then
RoadCompassMin = RoadCompassMin - 360
RoadCompassMin = RoadCompassMin + 360
End If
Dim PointBearing
PointBearing = [JOIN_CarData_RoadLinks.Bearing]
If PointBearing > RoadCompassMin And PointBearing < RoadCompassMax Then
CarOrientation = RoadOrientation
End if
If PointBearing < RoadCompassMin Or PointBearing > RoadCompassMax Then
If RoadOrientation = "-" Then
  CarOrientation = "+"
End if
If RoadOrientation = "+" Then
  CarOrientation = "-"
End if
End if
[/PHP]
I have tried including and excluding the "JOIN_CarData_RoadLinks." in my field allocations and replacing the declared variables used in the body of my code with the actual table's fields. I have copied my code into a VBScript IDE to check the syntax and it couldn't find anything wrong.
Any help would be appreciated.
Liam.
Outcomes
