Legend and scale bar
2504
10-03-2013 11:31 AM
KeisukeNozaki
Occasional Contributor II
I would like to add legend and scale bar to the following code.
I am little confused because many examples use web maps, not dynamic map services.
Thank you very much for your help.
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Create Map and add a dynamic layer</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css"/>
    <style>
      html,body,#mapDiv{
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script src="http://js.arcgis.com/3.7/"></script>
    <script>
      dojo.require("esri.map");
      var map;
      function init() {
        map = new esri.Map("mapDiv", {
          sliderOrientation: "vertical"
        var imageParameters = new esri.layers.ImageParameters();
        imageParameters.format = "jpeg";  //set the image type to PNG24, note default is PNG8.
        //Takes a URL to a non cached map service.
        var mcdonough = new esri.layers.ArcGISDynamicMapServiceLayer("", {
          "opacity":1,
        var aerials = new esri.layers.ArcGISDynamicMapServiceLayer("", {
          "opacity":1,
          "minScale":24000,
        map.addLayer(aerials);
        map.addLayer(mcdonough);
      dojo.ready(init);
    </script>
  </head>
  <body>
    <div id="mapDiv"></div>
  </body>
</html>
CaseySchneebeck
Here you go...
<!DOCTYPE html>
<html>
<head>
on iOS devices-->
<style>
html,body,#map{
padding:0;
margin:0;
height:100%;
#legendBox{
position:absolute;
bottom:60px;
left:10px;
z-index:100;
padding-left:5px;
padding-top:5px;
padding-bottom:0px;
background-color:#fff;
border:1px solid #555;
  -moz-box-shadow:0px 0px 5px #555;
  -webkit-box-shadow:0px 0px 5px #555;
</style>
<script>
dojo.require("esri.dijit.Scalebar");
dojo.require("esri.dijit.Legend");
var map;
function init() {
//create map
map = new esri.Map("map", {
  basemap: 'topo'
//create scalebar
var scalebar = new esri.dijit.Scalebar({
  map: map,
  attachTo: "bottom-left"
var mcdonough = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Population_World/MapSer...", {
  "opacity":0.5
var aerials = new esri.layers.ArcGISDynamicMapServiceLayer("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer", {
  "opacity":0.5
//add layers to map
map.addLayers([mcdonough, aerials]);
// create legendLayers array
var legendLayers = [];
//Push layers into array
legendLayers.push({layer:mcdonough,title:'McDonough Layer'});
legendLayers.push({layer:aerials,title:'Aerial Layer'});
//after layers are added use legendLayers to populate legend
dojo.connect(map, 'onLayersAddResult',function(results){
  legend = new esri.dijit.Legend({
   map:map,
   layerInfos:legendLayers
   },"legendDiv");
   legend.startup();
//call init function
dojo.ready(init);
</script>
</head>
<body>
<div id="map">
<div id="legendBox">
  <div id="legendDiv"></div>
</div>
</div>
</body>
</html>
CaseySchneebeck
//bring in required classes
Scalebar
//in the init function after you have created the map
map: map,
Legend
//div for legend - added style positioning if you want it
<div id="legendDiv" style="position:absolute; bottom:10px; left:10px; z-index:40"></div>
//array to store legend layers
//after you define your dynamic map service layers push them into the array
//add the legend
map:map,
},"legendDiv");
legend.startup();
Hope this helps,
Casey Schneebeck
The Nature Conservancy
KeisukeNozaki
I may have misplaced some codes, and legend does not show up.
Thank you so much for your help.
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <style>
      html,body,#mapDiv{
        padding:0;
        margin:0;
        height:100%;
    </style>
    <script>
      var map;
      function init() {
       map: map,
          "opacity":1,
          "opacity":1,
          "minScale":24000,
        map:map,
        },"legendDiv");
        legend.startup();
      dojo.ready(init);
    </script>
  </head>
  <body>
  </body>
</html>
CaseySchneebeck
Here you go...
<!DOCTYPE html>
<html>
<head>
on iOS devices-->
<style>
html,body,#map{
padding:0;
margin:0;
height:100%;
#legendBox{
position:absolute;
bottom:60px;
left:10px;
z-index:100;
padding-left:5px;
padding-top:5px;
padding-bottom:0px;
</style>
<script>
var map;
function init() {
//create map
  basemap: 'topo'
//create scalebar
  map: map,
  "opacity":0.5
  "opacity":0.5
//add layers to map
   map:map,
   },"legendDiv");
   legend.startup();
dojo.ready(init);
</script>
</head>
<body>
<div id="map">
</div>
</div>
</body>
</html>
