Tamplate picker issue
776
10-03-2013 07:14 AM
ChiranjeeviGK
New Contributor III
Hi all
i am trying to learn the TemplatePicker as in the example simpletoolbar.html
instead of loading the given layers as in example i added my layer which i have created from online arcGIS account,
i am not able to see any marker in the template picker panel.
here i have attached the code
[HTML]<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>Edit rivers and waterbodies</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/dojo/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.7/js/esri/css/esri.css" />
    <style>
      html,body{height:100%;width:100%;margin:0;overflow:hidden;}
      #map{
        padding:0;
      #header{
        font-size: 1.1em;
        font-family: sans-serif;
        padding-left: 1em;
        padding-top:4px;
        color:#660000;
      .templatePicker {
        border: none;
      .dj_ie .infowindow .window .top .right .user .content { position: relative; }
      .dj_ie .simpleInfoWindow .content {position: relative;}
    </style>
    <script src="http://js.arcgis.com/3.7/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/toolbars/edit",
        "esri/layers/ArcGISTiledMapServiceLayer",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/dijit/editing/Editor",
        "esri/dijit/editing/TemplatePicker",
        "esri/config",
        "dojo/i18n!esri/nls/jsapi",
        "dojo/_base/array", "dojo/parser", "dojo/keys",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map, Edit,
        ArcGISTiledMapServiceLayer, FeatureLayer,
        SimpleMarkerSymbol, SimpleLineSymbol,
        Editor, TemplatePicker,
        esriConfig, jsapiBundle,
        arrayUtils, parser, keys
        parser.parse();
        // snapping is enabled for this sample - change the tooltip to reflect this
        jsapiBundle.toolbars.draw.start = jsapiBundle.toolbars.draw.start +  "<br>Press <b>ALT</b> to enable snapping";
        // refer to "Using the Proxy Page" for more information:  https://developers.arcgis.com/en/javascript/jshelp/ags_proxy.html
        esriConfig.defaults.io.proxyUrl = "/proxy";
        //This service is for development and testing purposes only. We recommend that you create your own geometry service for use within your applications.
        esriConfig.defaults.geometryService = new esri.tasks.GeometryService("http://tasks.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
        map = new Map("map", {
          basemap: "satellite",
          center: [-96.541, 38.351],
          zoom: 14,
          slider: false
        map.on("layers-add-result", initEditor);
        //add boundaries and place names
        var labels = new ArcGISTiledMapServiceLayer("http://server.arcgisonline.com/ArcGIS/rest/services/Reference/World_Boundaries_and_Places/MapServer");
        map.addLayer(labels);
        var bangalore = new FeatureLayer("http://services1.arcgis.com/6KARYenaCPY4jndv/ArcGIS/rest/services/bangaloreDetails/FeatureServer/0",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['*']
        map.addLayers([bangalore]);
        function initEditor(evt) {
          var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result) {
            return { featureLayer: result.layer };
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: true
          var params = {settings: settings};
          var myEditor = new Editor(params,'editorDiv');
          //define snapping options
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
              5
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
    </script>
  </head>
  <body class="claro">
    <div id="main" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="height:width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane" id="header" data-dojo-props="region:'top'">
        Edit Hydrography
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width: 300px;overflow:hidden;">
        <div id="templateDiv"></div>
        <div id="editorDiv"></div>
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" id="map" data-dojo-props="region:'center'"></div>
    </div>
  </body>
</html>
[/HTML]
JohnGravois
after making sure i had a valid proxy reference and swapping the url in your app with a different feature service i was able to see editing templates so there doesn't appear to be anything wrong with the code.
http://sampleserver6.arcgisonline.com/arcgis/rest/services/ServiceRequest/FeatureServer/0
looking at your own service, it looks fine to me, but you might try publishing another one without picture marker symbology to see if something is wrong with your own symbology for some reason.
ChiranjeeviGK
New Contributor III
Thanks jgravois
i have copied the proxy.jsp in to my web app but i can not see the symbols.
i can see the error in the console as below
XMLHttpRequest cannot load http://server.arcgisonline.com/ArcGIS/rest/info?f=json. Origin http://localhost:8080 is not allowed by Access-Control-Allow-Origin.
is this the reason?
JohnGravois
the error you mentioned isn't the cause of the problem.  see this thread for more information.
you can test that your proxy is actually functioning by trying to load a page directly in the browser like this
http://servername/folder/proxy.jsp?http://sampleserver6.arcgisonline.com/arcgis/rest/services/Servic...
that being said, i checked the network traffic in my own app and in our live sample and the proxy doesn't seem to be needed to load the page so i think it would be better to focus on the service itself (as i mentioned previously)
ChiranjeeviGK
New Contributor III
Yes its issue with the symbol
i loaded a different layer which is working fine.
