I have tried to use the class break renderer with the result of a geoprocess but have had not luck so instead I wrote my own.
It renders the resulting counties according to the percent. However if I pan/zoom the map the colors revert to a default.
Any ideas on why this would happen? Also if anyone has a simple example of a class render working on the resulting features of a geoprocess I would like to see it.
Here is the function that receives the output and draws it to screen. This works fine until I pan or zoom - then the polygons loose their symbology.
function drawMap(results, messages) {
console.log("geocodeCountGP is running");
var polySymbol = new esri.symbol.SimpleFillSymbol();
polySymbol.setOutline(new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleLineSymbol.STYLE_SOLID, new dojo.Color([0,0,0,1]), 1));
polySymbol.setColor(new dojo.Color([56, 150, 0,0.9]));
var features = results[0].value.features;
var infoTemplate = new esri.InfoTemplate("${COUNTY}","Count: ${Join_Count}");
for (var f=0, fl=features.length; f<fl; f++) {
var feature = features;
percent = features.attributes.Percent;
if (percent < 5) {polySymbol.setColor(new dojo.Color([255,255,51,.5]))};
if (percent >= 5 && percent < 10) {polySymbol.setColor(new dojo.Color([56, 168, 0,0.25]))};
if (percent >= 10 && percent < 20) {polySymbol.setColor(new dojo.Color([56, 168, 0,0.5]))};
if (percent >= 20) {polySymbol.setColor(new dojo.Color([56, 168, 0,0.75]))}
feature.setSymbol(polySymbol);
map.graphics.add(feature);
map.graphics.add(feature.setInfoTemplate(infoTemplate));
