Internal error in the geometry system
3333
10-01-2013 05:06 AM
GregYetman
I'm experimenting with creating a schematic based on a network dataset (bus routes). I setup the schematic based on the blog post here:
http://blogs.esri.com/esri/arcgis/2007/12/12/create-route-maps-with-the-arcgis-schematics-extension/
However, when I try and build the schematic I get the error message:
[INDENT]Error during schematic diagram generation.
An internal error has occurred in the geometry system.[/INDENT]
Any suggestions on how to figure out what is wrong with my network? Running Desktop 10.2.
TIA,
Greg
RickAnderson
Occasional Contributor III
That is an older article.  We have added a builder specifically for network datasets since then.  You should probably have a quick look at this quick start information:
Quick Start
and the video called Configuring the Network Dataset Builder found in the video series
See if those help.
RickAnderson
Quick Start
See if those help.
