Simply talk about "syc. about Map And PageLayout"
453
09-29-2013 08:19 PM
JcsonJcson
I am confuse about the "syc. about Map And PageLayout".
As I posted a thread before, the same issue about this.But nobody reply.Sad about saying this.
Here is the siple code:
//Swith page between "Map" and "PageLayout".
        private void tabControl1_SelectedIndexChanged(object sender, EventArgs e) {
            if (tab_control.SelectedIndex == 0) {   //Switch to the Map View page.
                toolbar.SetBuddyControl(map);
                toc.SetBuddyControl(map);
            else if (tab_control.SelectedIndex == 1) {  //Switch to the PageLayout page.
                toolbar.SetBuddyControl(page_layout);
                toc.SetBuddyControl(page_layout);
        private void FormMain_Load(object sender, EventArgs e) {
            //Set the Map as the buddies for the ToolBar and TOCControl.
If this code run in a App that is not contain a stuff called "LicenseInitializer.cs". The App will auto shut down when I switch the Page
"Map" to "PageLayout".That is to say,I just do not know what the sfuff "LicenseInitializer.cs" do, the APP runs normal when switch the
same way.
AlexanderGray
Occasional Contributor III
The license initializer initializes the ArcGIS (engine runtime, advanced etc.) that is necessary to use ArcObjects components.  Without a license attempting to use ArcObjects classes will fail.
JcsonJcson
Thanks for answering. It seems that the license do something,and that is what I thought about,but can you just launch me sth. such as If the initializer launch the code or not.I mean that the work is done behind or lauch us the code about that.
AlexanderGray
I am not sure I follow.  The license initializer may or may not be used in your code.  Typically that gets added to the project when you use an esri template.  I don't know what type of project, form, console, library you have.  It might be called in the application initialization events, in the main function of a class or in the load of a form.  The best thing is to search for references to it in your code.
JcsonJcson
I have overviewed the code in the initializer,but I do't know which is something we talk about,It seems unabvious.you know that,therefore I do not how to search for the reference. Thanks all the same.
