AnsweredAssumed Answered
I want to use arcpy to dynamically position a graphic element on my Layout
Question asked by GISGURU_001 on Sep 29, 2013
Latest reply on Oct 7, 2013 by mdenil
I want to use arcpy to dynamically position a graphic element on my layout, I have parcels with different shape and size. The position of the parcel affects my graphic element when it is static. I want to use the number of lines that form the parcels to dynamically position  the graphic element on the layout sheet i.e. if the number of lines is 4 it should be at a particular position, if it is 6 then the position should also change dynamically? Any suggestions, Thanks
Outcomes
