I am using Esri out of box printing service (..../arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task) to export a map (in pdf or jpg). The extent value is passed as json parameter to this service. When the map view is across the anti-meridian line, the exported map is cut off along that line, i.e., only show one side of the line, the other side is blank. Does anyone know if this is a bug in the Arcgis service? Any solution/workaround for that?
Your kind help is greatly appreciated.
