ArcGIS Server 10.2 Create new site fails
8907
10
09-25-2013 02:33 AM
DaveAdams
New Contributor III
I have installed Server 10.2 as a fresh install - I removed 10.1 first. I have installed successfully and authorised with no issues. However when I try and create the new site the process takes forever and eventually bails - the error message is "failed to create site - failed to create default cluster".
I have investigated the logs in /usr and found the following - the creation of server directories etc seems fine but then
<Msg time="2013-09-25T09:02:14,216" type="SEVERE" code="6550" source="Admin" process="3036" thread="13" methodName="" machine="DAVEY-PC" user="" elapsed="">Failed to start the server machine 'DAVEY-PC'. Could not start application server within stipulated time.</Msg>
This is then followed by a series of other errors including 6518, 6516 and 6533
the server is up and running - I had no similar problems when I installed 10.1 on the same machine a few months ago
Any ideas would be appreciated - I have installed 2 or 3 times now and stopped and started the service etc.
BubbaHey
Occasional Contributor III
Are you creating single site or are you getting this error on a join?
Make sure the machine name has no unsupported characters, this can be a problem. I've even seen underscores cause problems.
DaveAdams
New Contributor III
It's a single new site - the only non letter character is a hyphen "-" - I have seen reference to underscores and multi-byte characters - are hyphens also a problem?
BubbaHey
It shouldn't be a problem but if you can try without the hyphen
DaveAdams
New Contributor III
Bubba
unfortunately the name change only got me back to the same point - the hyphen wasn't the issue it seems. Here is a longer extract of the error log text
<Msg time="2013-09-27T10:05:54,214" type="SEVERE" code="6550" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Failed to start the server machine 'DAVEYPC'. Could not start application server within stipulated time.</Msg>
<Msg time="2013-09-27T10:05:54,220" type="SEVERE" code="6550" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Failed to start the server machine 'DAVEYPC'. Failed to start the server machine 'DAVEYPC'. Could not start application server within stipulated time.</Msg>
<Msg time="2013-09-27T10:05:54,222" type="SEVERE" code="6518" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Failed to start the cluster 'default'. One or more server machines could not be started.</Msg>
<Msg time="2013-09-27T10:05:54,229" type="SEVERE" code="6516" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Failed to create the cluster 'default'. One or more server machines could not be started.</Msg>
<Msg time="2013-09-27T10:05:54,230" type="SEVERE" code="6533" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Failed to create the site. Failed to create the cluster 'default'. One or more server machines could not be started.</Msg>
<Msg time="2013-09-27T10:05:54,234" type="INFO" code="7057" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Disconnecting the site from the configuration store.</Msg>
<Msg time="2013-09-27T10:06:04,408" type="INFO" code="6552" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Server machine 'DAVEYPC' was stopped successfully .</Msg>
<Msg time="2013-09-27T10:06:04,410" type="INFO" code="6519" source="Admin" process="5932" thread="13" methodName="" machine="DAVEYPC" user="" elapsed="">Cluster 'default' stopped successfully.</Msg>
cheers
Dave
BubbaHey
Hmm. Not sure, maybe try deleting the arcgisserver folder and run Setup again
DaveAdams
New Contributor III
Got a little frustrated so I thought I would try an upgrade install rather than fresh - I uninstalled all ESRI software and looked around for any remnant files/directories leftover and removed those also. I also deleted the arcgis user account etc. Then I installed 10.1 and it worked first time with no problems installing or creating the site - I'll try the 10.2 install next and let you know. There must be something different in the 10.2 install from scratch...
DaveAdams
New Contributor III
Gave up - the install over the top of 10.1 hung when trying to bring up the server manager after install - couldn't get any further even after stopping and starting the server and trying to go into the manager manually etc. Gone back to 10.1 which installs and works first time - will get on with some development work and keep my eye out if someone else gets the same issues and a solution before heading back to 10.2. Thanks Bubba for the suggestions - something must be left behind on my PC which 10.2 is not happy with during the install process.
Cheers
YungKaiChin
Try remove or rename these after uninstall ArcGIS 10.2 "may" help:
1. arcgisserver folder
2. Program Files\ArcGIS\Server folder
3. Program Files\ESRI\License10.2\sysgen\keycodes file
muhannadS_
problem is resolved, here is the scenario for any one who encounters this problem in the future:
initially I had the problem "Failed to create the site. Failed to configure the server machine 'PC.LOCALDOMAIN'. Server machine 'PC.LOCALDOMAIN' is not a local server machine.".
after following ykchin's advice and editing both files, I encountered the 'cannot create the default cluster error', I checked the user log & it stated the same error specified above 'cannot start application server within the stipulated time', I checked the arcgis user under computer management, local users and groups, users & it was only a member of the Users group, adding it to the Administrators group solved the problem & created the site under ArcGIS server admin.
