I have created some jp2 images in ERMapper 2013, also some ecws from the same datasets. When displayed in ArcMap 10.0 SP5, the ecws are in the correct geographic location, but the jp2 images have their lat/long coords inverted. Earlier versions of ERMapper/ArcMap didnt cause this problem.
Which software is causing the problem, and can it be fixed?
Just quickly try one image (UTM/WGS 84 & local datum) to export JP2 with ER Mapper 2013 SP1 (that is, 'ERDASIMAGINE2013_13.00.0001.exe') and looks OK for ArcGIS 10.0 SP5 (no errors spatially).
Regards,
