Appending Data Into Existing Geometric Network
2364
09-23-2013 12:32 PM
TimRooney
Hi all,
I"m currently interning at a telecommunication company and have been tasked with converting their CAD maps into their GIS telecom model. I've been using FME to translate the CAD data with great success, but i've been roadblocked at the final step, which is appending the translated feature classes into the telecom model, necessary for the data to be uploaded to our Oracle database. The data that I'm outputting from FME is in simple line feature format and i'm trying to append these features to their corresponding empty feature classes that are in complex edge format. If you have any ideas please let me know.
Thanks.
-Tim
KaraManseau1
Hi Tim,
Have you tried using the Object Loader? This allows you to load data into feature classes that are participating in a geometric network. Please follow the links below for more information regarding this tool:
'>About loading data in ArcMap
'>Adding the Load Objects command to ArcMap
- Kara M.
TimRooney
I have tried. The issue i'm facing is that the schemas are different, when I append I use the "no-test" option.
