Hi all,
I'm using ArcGIS Server 10.0 sp5 .NET WebADF and NITK toolkit. I made a simple button to zoom to MGRS coordinates and would like the resulting X & Y values in UTM WGS84 14. Executing PutCoordsFromMGRS (from the IConversionMGRS class) always returns a Lat/Long for a X,Y value.
When I go to project the value back to UTM WGS84 14N, I get no change....what am I missing?
private void ZoomToMGRSCoordinate(string MGRSValue)
//We finally get to start the conversion of MGRS to Points
IServerContext serverContext = null;
GISServerConnection serverConnection = new GISServerConnection();
serverConnection.Connect("LocalHost");
IServerObjectManager serverManager = serverConnection.ServerObjectManager;
//Get GeometryServer Context
serverContext = serverManager.CreateServerContext("Geometry",
"GeometryServer");
ISpatialReferenceFactory3 pSRF = serverContext.CreateObject(
"esriGeometry.SpatialReferenceEnvironment") as ISpatialReferenceFactory3;
ISpatialReference utmSpatialReference = pSRF.CreateProjectedCoordinateSystem((int)esriSRProjCSType.esriSRProjCS_WGS1984UTM_14N);
ISpatialReference ddSpatialReference = pSRF.CreateGeographicCoordinateSystem((int)esriSRGeoCSType.esriSRGeoCS_WGS1984);
ESRI.ArcGIS.Geometry.IPoint pnt = new PointClass();
if (Map.PrimaryMapResource.ToString() == "FSC" || Map.PrimaryMapResource.ToString() == "FSR")
pnt.SpatialReference = ddSpatialReference;
IConversionMGRS convertpnt = pnt as IConversionMGRS;
convertpnt.PutCoordsFromMGRS(MGRSValue, esriMGRSModeEnum.esriMGRSMode_USNG);
ESRI.ArcGIS.Geometry.IPoint pnt2 = new PointClass();
pnt2.SpatialReference = ddSpatialReference;
pnt2 = convertpnt as IPoint;
pnt2.Project(utmSpatialReference);
pnt2.SnapToSpatialReference();
ESRI.ArcGIS.ADF.Web.Geometry.Point wpn = ESRI.ArcGIS.ADF.Web.DataSources.ArcGISServer.Local.Converter.FromIPoint(pnt2)
MapZoomer mapZoomer = new MapZoomer(Map, PointZoomFactor);
mapZoomer.ZoomToGeometry(wpn);
