after mistakinly using the field calculator, data on 1 field on the attribute table rename all the records with zeros(0)/nulls.how do i recover the correct data
Did you do this in an edit session? If so, did you save your edits? If you did that, then it is permanent, this is the same if you calculated data out of edit.
