AnsweredAssumed Answered
Raster creation help
Question asked by timdj on Sep 16, 2013
Latest reply on Sep 1, 2014 by curtvprice
I apologise if this has been answered before, as it seem like quite a basic question but I couldnt find a solution. (9.3, ArcView license with spatial analyst and 3D analyst).
I am trying to calculate the volume of water that would be impounded by a hypothetical dam using cut/fill, and I am having trouble creating the "after" raster.
I have an elevation raster (Ras1) and a polygon of the surface of the potential reservoir formed by the dam and a 450m contour.
I used "extract by mask" to create a raster of the reservoir and reclassified this to a constant 450m (Ras2).
I am now trying to create a raster (Ras3) that is identical to Ras1 apart from the area covered by Ras2, which should take the Ras2 values (450)
I have tried using raster calculator an con([Ras1] > 0, [Ras1], [Ras2]) but the output is identical to Ras2, with no data from Ras1.
Where am I going wrong with this? and is this even a sensible method?
Once I have Ras3 I am assuming cut/fill with Ras1 as "before" and Ras3 as "after" will give me the volume
I have found the volume using TIN polygon volume already but I want to compare it with the cut/fill method
Tim
Outcomes
