ArcGIS Server 10.0 SP5ArcGIS Javascript API 3.6I'm passing a the geometry of a drawn graphic to a parameter in my Identify url. Everything is working fine except when I pass the geometry of a polygon circle. I'm pretty sure the issue is because I'm passing many polygon rings into the parameter and my service is not liking that.Do I need to "generalize" my circle before passing it's geometry or can I limit the maximum number of rings a circle can have when being drawn?Here's the workflow:First I draw a shape. Each shape references a geometry in a Draw toolbar I created. For circle I am setting the drawing toolbar like so:tb.activate(esri.toolbars.Draw.CIRCLE);
*Note, I did notice options can be passed in the activate, but cannot find those available options in the API.I then create my url parameters on the "draw-end" event:tb.on("draw-end", createSelectURL);
identifyURL + "&geometry=" + JSON.stringify(e.geometry)
...and as I stated before, this works.So, are my options just to generalize the shape geometry, or can I limit the number of rings before drawing the shape, or perhaps there is something I am not thinking of?Any help is appreciated, and to all, Happy Friday!Thanks,Chris B.
