steinj14
upgrading api from 3.2 to 3.5 causing error "map.spatialReference undefined"
Discussion created by steinj14 on Sep 12, 2013
Latest reply on Sep 12, 2013 by kenbuja
In trying to upgrade the api, I'm getting an error on this line:
console.log(esri.geometry.getScale(map.extent, map.width, map.spatialReference.wkid));
which is called after the following:
    configExtent = {
     "xmin" : -9215700,
     "ymin" : 3216400,
     "xmax" : -9119800,
     "ymax" : 3256100,
     "spatialReference" : {
      "wkid" : 102100
 var initialExtent = new esri.geometry.Extent(configExtent);
 var lods = configLods;
 var popup = new esri.dijit.Popup(null, dojo.create("div"));
 //Set map parameters.
 map = new esri.Map("map", {
  extent : initialExtent,
  logo : false,
  infoWindow : popup,
  slider : true,
  sliderStyle : "default", //use 'small' if you want just the +/- icons
  nav : true, //shows the pan buttons.
  lods : lods, //sets the navigation slider to the specified levels.
  showAttribution : false
Has something changed in 3.5 to make this not work?
Joan
Outcomes
