bmwgsbill
Table Summary
Discussion created by bmwgsbill on Sep 9, 2013
Latest reply on Sep 10, 2013 by zj_zou
I am working with the example 'Query with Feature Layer' and I am trying to get some totals from the table.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="X-UA-Compatible" content="IE=7, IE=9, IE=10">
  <title>Page through records</title>
  <style>
    html, body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
      overflow: hidden;
      font-family: "Roboto Condensed", sans-serif;
      font-size: 0.90em;
      margin: 0 auto;
      width: 750px;
    #grid {
      height: 336px;
      width: 100%;
    .field-name {
      width: 200px;
      font-size: .80em;
      font-weight: normal;
    .field-magnitude {
      width: 50px;
      font-size: .80em;
    .field-deaths {
      width: 70px;
      font-size: .80em;
    .field-date {
      width: 70px;
      font-size: .80em;
    #grid .dgrid-row-odd {
      background: #F2F5F9;
  </style>
  <script src="http://js.arcgis.com/3.6/">
  </script>
  <script>
    var featureLayer, pageInfo, grid;
    require([
      "esri/layers/FeatureLayer", "esri/tasks/query", "esri/TimeExtent",
      "dojo/number", "dojo/date/locale", "dojo/dom","dojo/on",
      "dojo/_base/array", "dojo/store/Memory",
      "dgrid/OnDemandGrid", "dojo/domReady!"
    ], function(
      FeatureLayer, Query, TimeExtent,
      number, locale, dom, on,
      arrayUtils, Memory,
      OnDemandGrid
      // create a dgrid
      var sortAttr = [{
        attribute: "magnitude",
        descending: true
      grid = new OnDemandGrid({
        store: Memory({
          idProperty: "name"
        columns:{
          magnitude: {
            label: "Magnitude",
            formatter: formatRound
          deaths: "Deaths",
          date:{
            label: "Date",
            formatter: formatDate
        sort: sortAttr
      }, "grid");
      // create a feature layer
      featureLayer = new FeatureLayer("http://sampleserver3.arcgisonline.com/ArcGIS/rest/services/Earthquakes/Since_1970/MapServer/0", {
        outFields:["*"]
      // get object IDs from the table (feature layer)
      featureLayer.on("load", function () {
        // create the query to fetch object IDs for earthquakes that have a magnitude greater than 6.0
        // that occurred after January 1st 2007
        var query = new Query();
        query.where = "Magnitude > 6.0 AND Num_Deaths >= 1";
        query.timeExtent = new TimeExtent(new Date("01/01/2007 UTC"));
        featureLayer.queryIds(query, function (objectIds) {
          fetchRecords(objectIds);
      // click listeners for prev/next page buttons
      on(dom.byId("prev"), "click", function() {
        queryRecordsByPage(pageInfo.currentPage - 1);
      on(dom.byId("next"), "click", function() {
        queryRecordsByPage(pageInfo.currentPage + 1);
      // formatting function for numbers
      function formatRound(value) {
        return number.round(value, 2);
      // formatting function for dates
      function formatDate(value) {
        var inputDate = new Date(value);
        return locale.format(inputDate, {
          selector: "date",
          datePattern: "MMMM d, y"
      function fetchRecords(objectIds) {
        if (objectIds.length > 0) {
          updatePageInformation(objectIds);
          queryRecordsByPage(1);
        } else {
          grid.showMessage("No matching records");
          grid.setStore(null);
      function updatePageInformation(objectIds, page) {
        pageInfo = {
          objectIds: objectIds,
          totalRecords: objectIds.length,
          totalPages: Math.ceil(objectIds.length / 15),
          currentPage: page || 0,
          recordsPerPage: 15
        dom.byId("pageInfo").innerHTML = pageInfo.currentPage + "/" + pageInfo.totalPages;
        dom.byId("recordsInfo").innerHTML = pageInfo.totalRecords;
        if (pageInfo.currentPage > pageInfo.totalPages) {
      function queryRecordsByPage(pageNumber) {
        // check if the page number is valid
        if (pageNumber < 1 || pageNumber > pageInfo.totalPages) {
          return;
        //grid.showMessage("Fetching records...");
        var begin = pageInfo.recordsPerPage * (pageNumber - 1);
        var end = begin + pageInfo.recordsPerPage;
        // create the query
        query.objectIds = pageInfo.objectIds.slice(begin, end);
        query.outFields = ["*"];
        // Query for the records with the given object IDs and populate the grid
        featureLayer.queryFeatures(query, function (featureSet) {
          updateGrid(featureSet, pageNumber);
      function updateGrid(featureSet, pageNumber) {
        var data = arrayUtils.map(featureSet.features, function (entry, i) {
          return {
            magnitude: entry.attributes.Magnitude,
            deaths: entry.attributes.Num_Deaths,
            date: entry.attributes.Date_
        grid.store.setData(data);
        grid.refresh();
        // update application state
        pageInfo.currentPage = pageNumber;
  </script>
</head>
<body>
<p>
  Total records:
  <span id="recordsInfo">0</span>
  <button id="prev">Prev Page</button>
    <span id="pageInfo"></span>
  <button id="next">Next Page</button>
</p>
<!-- dgrid will be created in this div -->
<div id="grid"></div>
</body>
</html>
If I understand the code correctly, this section gives the total number or records at the top of the table:
        pageInfo = {
          recordsPerPage: 15
The example gives a table with earthquake name and Magnitute.  At the top it list the total records: 29.  Now this is where I need some help.  What would I need to add to the code to illustrate a list of how many of each there are.  I need a summary on the name.
Example:
JAPAN: HONSHU: W COAST : 2
KYRGYZSTAN: NURA: 1
HONDURAS : 1
...etc.
Does this make sense?  Any help is much appreciated.
Outcomes
