bb1769
"seperateImage" misspelling in generateKml request
Discussion created by bb1769 on Sep 6, 2013
The REST API documentation under "Generate KML" has this sample request to generate a KML/KMZ file for a map service:
http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Specialty/ESRI_StatesCitiesRivers_USA/MapServer/generatekml?docName=Test+Name&layers=1,2&layerOptions=separateImage
This works fine for this server, which is at 10.01. However, the same approach does not work on our 10.1 server: it ignores the separateImage and instead sets the KML to use the composite option.
It turns out there is a misspelling in the expected separateImage parameter - it works if I use "seperateImage" instead! Oddly enough, the ...MapServer/generateKml page uses this misspelling to generate KML that does separate layers. Hopefully the software team will correct this; meanwhile heads up if you're generating such links.
BTW, I do not work for ESRI - I did but left the company in 2009.
Outcomes
