I have features in my mxd referencing and SDE database. When I go to publish, I enable feature access so users in the field can edit. When I go into arcgis online to create my web map, everything looks fine and editing is enabled. However, after I save my web map and check to make sure people can use it in the field for editing, nothing shows up. The web map populates with a blank screen on iPad app. Same thing in ArcGIS explorer. The only time it works is when I am using the web map itself I created online. Any ideas what is causing this?
Laura
