Making an atlas of thematic maps with DDP
476
09-03-2013 07:30 AM
JasmineBath
HELP!
Trying to used arcpy and ddp to make a series of pdfs (or one large pdf) that displays five different layers turned on and off for each index feature.
I have found serveral different codes that all could be helpful, but I'm having toruble putting them together.
From http://blogs.esri.com/esri/arcgis/2010/12/14/combining-data-driven-pages-with-python-and-arcpy-mappi...
import arcpy, os
#Specify output path and final output PDF
outPath = r�?�C:MyProjectoutput\�?�
finalPdf = arcpy.mapping.PDFDocumentCreate(outPath + �??ParcelReport.pdf�?�)
#Specify the map document and the data frame
mxd = arcpy.mapping.MapDocument(r�?�C:MyProjectMyParcelMap.mxd�?�)
df = arcpy.mapping.ListDataFrames(mxd, �??Layers�?�)[0]
#Select a parcel using the LocAddress attribute and zoom to selected
parcelLayer = arcpy.mapping.ListLayers(mxd, �??Parcels�?�, df)[0]
arcpy.SelectLayerByAttribute_management(parcelLayer, �??NEW_SELECTION�?�, �??�?�LocAddress�?� = �??519 Main St�??�?�)
df.zoomToSelectedFeatures()
#Turn on visibility for each theme and export the page
lyrList = ["Soils", "Floodplains", "Zones"]
for lyrName in lyrList:
     lyr = arcpy.mapping.ListLayers(mxd, lyrName, df)[0]
     lyr.visible = True
     #Export each theme to a temporary PDF and append to the final PDF
     tmpPdf = outPath + lyrName + �??_temp.pdf�?�
     if os.path.exists(tmpPdf):
          os.remove(tmpPdf)
     arcpy.mapping.ExportToPDF(mxd, tmpPdf)
     finalPdf.appendPages(tmpPdf)
     #Turn off layer visibility and clean up for next pass through the loop
     lyr.visible = False
     del lyr, tmpPdf
del mxd, df, finalPdf
Will this loop through all the index features in my map?
Thanks!
JeroenWisse
I am not entirely sure what you are trying to do.
Could you please explain it.
Also when you post code can you use the code tag? It makes the code more readable.
JasmineBath
Basically I have 800+ districts and for each one I want to create a PDF with five different maps (five different layers turned on and off).
So instead of five 800-page pdfs, or 800 * 5 individual pdfs, I want 800 pdfs each with five page.
JeroenWisse
I haven't tested this code but it should work, or at least not much editing 🙂
outPath = r"C:MyProjectoutput\"
finalPdf = arcpy.mapping.PDFDocumentCreate(outPath + "ParcelReport.pdf")
mxd = arcpy.mapping.MapDocument(r"C:MyProjectMyParcelMap.mxd")
df = arcpy.mapping.ListDataFrames(mxd, "Layers")[0]
parcelLayer = arcpy.mapping.ListLayers(mxd, "Parcels", df)[0]
arcpy.SelectLayerByAttribute_management(parcelLayer, "NEW_SELECTION", "LocAddress" = '519 Main St')
    lyr.visible = True
    tmpPdf = outPath + lyrName + "_temp.pdf"
        os.remove(tmpPdf)
    lyr.visible = False
    del lyr, tmpPdf
The above code only exports the 3 pdf's for location address 519 Main St.
The layers it sets as visible are Soils,Floodplains and Zones.
If you want to automate the entire process then you need to have a list or a way to get the locaddresses.
You could then loop trough the location adressess like this:
for locaAddress in locAdresses:
    finalPdf = arcpy.mapping.PDFDocumentCreate(outPath + "ParcelReport "+locAddress+".pdf")
    arcpy.SelectLayerByAttribute_management(parcelLayer, "NEW_SELECTION", "LocAddress" = locAddress)
        lyr.visible = True
            os.remove(tmpPdf)
        lyr.visible = False
        del lyr, tmpPdf
Again the above code isn't tested but the idea is that it should give you 800 pdf's name for example ParcelRepor t519 Main St.pdf
It should contain 3 pages (because the lyrList has 3 items).
I hope this helps
