philojuan
Simple FeatureLayer Selection not working
Discussion created by philojuan on Aug 23, 2013
Hello All,
Can someone please look at this code and tell me why the selection is not showing up ? All I am trying to do is select a parcel when the page loads .
The map zooms to the correct extent but does not highlight the parcel(s) . Sometimes it can return multiple results.
The code itself is a simplified modified version of the example here https://developers.arcgis.com/en/javascript/jssamples/exp_history.html
Thanks in advance.
<script>
var map;
var parcels;
require([
        "esri/map", "esri/layers/FeatureLayer",
        "esri/layers/ArcGISTiledMapServiceLayer", "esri/tasks/query",
        "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/graphic", "esri/dijit/Popup", "esri/dijit/PopupTemplate",
        "esri/urlUtils", "esri/graphicsUtils",
        "dojo/_base/Color",
        "dojo/on", "dojo/query", "dojo/parser", "dojo/dom-construct",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Map, FeatureLayer,
        ArcGISTiledMapServiceLayer, Query,
        SimpleFillSymbol, SimpleLineSymbol,
        Graphic, Popup, PopupTemplate,
        urlUtils, graphicsUtils,
        Color,
        on, query, parser, domConstruct
   //apply a selection symbol that determines the symbology for the selected parcel
   var sfs = new SimpleFillSymbol(
     SimpleFillSymbol.STYLE_SOLID,
     new SimpleLineSymbol(
    SimpleLineSymbol.STYLE_SOLID,
    new Color([111, 0, 255]),
     new Color([111, 0, 255, 0.15])
   map = new Map("map", { slider:false, logo:false, basemap: "hybrid" , extent: new esri.geometry.Extent({"xmin":-9857930.663880095,"ymin":4551977.908437532,"xmax":-9408480.93756328,"ymax":5155524.683777255,"spatialReference":{"wkid":102100}}) });
   parcels = new FeatureLayer("MAP_SERVICE_URL",
          { outFields: ['PIN_18'], mode: FeatureLayer.MODE_SELECTION });
   parcels.setSelectionSymbol(sfs);
   map.on("layers-add-result", function (result) {
    var parcelid = "53-01-40-109-616.000-008";
    selectParcel(parcelid);
   map.addLayers([parcels]);
   function selectParcel(parcelid) {
    var query = new Query();
    query.where = "PIN_18 = '"  + parcelid + "'";
    query.outSpatialReference = 102100;
    var deferred = parcels.selectFeatures(query, FeatureLayer.SELECTION_NEW,
    function (selection) {
     console.log(selection);
     //var center = graphicsUtils.graphicsExtent(selection).getCenter();
     var extent = graphicsUtils.graphicsExtent(selection).expand(5);
     // zoom to center and set extent
     //map.centerAt(center);
     map.setExtent(extent);
Outcomes
