Hi allI am using the Toolbar from this sample: https://developers.arcgis.com/en/javascript/jssamples/toolbar_navigation.htmlbut in my program when I Zoom In the first time it works but the second time it looks like it gets confused with the Pan button, so it does not Zoom in, and it draws the zoom in window from bottom to top even if the zoom in is drawn from top to botton.//create the map and specify the custom info window as the info window that will
//be used by the map
map = new esri.Map("map", {
extent: mapExtent
// Loading image
dojo.connect(map, "onUpdateStart", showLoading);
dojo.connect(map, "onUpdateEnd", hideLoading);
//Takes a URL to a map in a map service.
var dynamicUrl = "";
dynamicUrl = "http://...../ArcGIS/rest/services/OneLayer/MapServer"
var dynamicLayer = new esri.layers.ArcGISDynamicMapServiceLayer(dynamicUrl);
legendLayers.push({ layer: dynamicLayer, title: "Dolfin" });
dojo.connect(map, 'onLayersAddResult', function (results) {
//add the legend
var legend = new esri.dijit.Legend({
map: map,
layerInfos: legendLayers,
arrangement: esri.dijit.Legend.ALIGN_LEFT
}, "legendDiv");
legend.startup();
var standardTOC = new agsjs.dijit.TOC({
map: map
}, 'standardDiv');
standardTOC.startup();
map.addLayers([dynamicLayer]);
//define the info template that is used to display the popup content.
var infoTemplate1 = new esri.InfoTemplate("Attributes", "${*}");
//create the feature layer (street trees of San Francisco)
var featureLayer = new esri.layers.FeatureLayer("http://jsancn-3-doug/ArcGIS/rest/services/OneLayer/MapServer/0",{
mode: esri.layers.FeatureLayer.MODE_ONDEMAND,
infoTemplate: infoTemplate1,
outFields: ["*"]
map.addLayers([featureLayer]);
//resize the info window
map.infoWindow.resize(180, 75);
navToolbar = new esri.toolbars.Navigation(map);
dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
//add check boxes
dojo.forEach(legendLayers, function (layer) {
var layerName = layer.title;
var checkBox = new dijit.form.CheckBox({
name: "checkBox" + layer.layer.id,
value: layer.layer.id,
checked: layer.layer.visible,
onChange: function (evt) {
var clayer = map.getLayer(this.value);
clayer.setVisibility(!clayer.visible);
this.checked = clayer.visible;
//add the check box and label to the toc
dojo.place(checkBox.domNode, dojo.byId("toggle"), "after");
var checkLabel = dojo.create('label', { 'for': checkBox.name, innerHTML: layerName }, checkBox.domNode, "after");
dojo.place("<br />", checkLabel, "after");
//resize the map when the browser resizes - view the 'Resizing and repositioning the map' section in
//the following help topic for more details http://help.esri.com/EN/webapi/javascript/arcgis/help/jshelp_start.htm#jshelp/inside_faq.htm
// dojo.connect(map, 'onLoad', function (theMap) {
// //resize the map when the browser resizes
// dojo.connect(dijit.byId('map'), 'resize', map, map.resize);
var resizeTimer;
dojo.connect(map, "onLoad", function (map) { map.infoWindow.resize(250, 100); });
dojo.connect(dijit.byId('map'), 'resize', function () { //resize the map if the div is resized
clearTimeout(resizeTimer);
resizeTimer = setTimeout(function () {
map.resize();
map.reposition();
}, 500);
//after map loads, connect to listen to mouse move & drag events
dojo.connect(map, "onMouseMove", showCoordinates);
dojo.connect(map, "onMouseDrag", showCoordinates);
//add the overview map
var overviewMapDijit = new esri.dijit.OverviewMap({
map: map,
visible: false
overviewMapDijit.startup();
//show map on load
dojo.addOnLoad(init);
