http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/variables.less does not compile
1060
08-22-2013 01:51 PM
Ashwiniw
Hello All,
So I looked at http://js.arcgis.com/3.6/js/dojo/dijit/themes/claro/variables.less and I would like to edit some colors in it, but prior to doing that I wanted to convert it to css just to see that the process works, so tried lessc on my comp a windows pc, also on crunchapp and also http://less2css.org/ live preview page in all the cases the conversion results in a blank css file. Can anyone help / advise on what I am doing wrong?
Thanks for your help in advance.
Ashwini
ReneRubalcava
That particular less file is all mixins and variable declarations, there's no actual css to be compiled.
The mixins would get used in a css style, like
div.map-container {
  .gradient-and-filter(@primary-color, 10, 10)
You can see this by copy/pasting all the less into the less2css site, then add the snippet above to see the results.
Here is a page describing how less mixins are used.
http://www.sitepoint.com/a-comprehensive-introduction-to-less-mixins/
Ashwiniw
div.map-container {
Hello Rene,
Thanks for your reply. I suppose I have to read up on mixins but in the short term if I change colors in variables.less for claro theme, how do I make sure that changes will occur in the output html file, and which file do I reference in the stylesheet tag because the claro theme is currently referenced with stylesheets hosted online, and I thought that I will modify less, regenrate css and link it locally. Can you please advise..
Ashwini
